Working with AutoCAD 64 bits
Message 1 of 9
Hi My 32 bits .net application works on 32 bits machines but is crashes on 64 bits ones with the following error
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.InvalidCastException: Unable to cast COM object of type 'System.__ComObject' to interface type 'Autodesk.AutoCAD.Interop.AcadApplication'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{8F17437C-2EFB-4FC4-8188-EEFA50FE7147}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)
It looks like it stops when trying to execute the following statement
Dim AcadApp As Autodesk.AutoCAD.Interop.AcadApplication = CType(Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication, Autodesk.AutoCAD.Interop.AcadApplication)
Any help I will appreciate Raul
Replies (8)
Message 2 of 9
First keep in mind I'm no expert, but I tried this also. When your
assembly is built with an early bind to a 32bit AutoCAD COM it won't
run in 64bit. I 'suppose' you could change the COM link to a 64bit
AutoCAD COM and prepare a separate 64bit build.
In my opinion your better off porting all your COM/ActiveX code to pure
.NET and use the AnyCPU compile option. Then use 'late bound' COM only
for the rare instance that it cannot be done in .NET.
My ports are 99.9% pure .NET as of right now and a single build loads
and runs fine in AutoCAD 2007 or higher, 32 or 64bit.
Good Luck, Terry
Message 3 of 9
Hi Terry,
Thanks for your answer, eventually I will find the way to go pure .Net (no COM involved) in the meantime, do you know the best way to get the current runtime AutoCAD application object without using com interop?.
Raul
Message 4 of 9
Hi Terry,
Raul
Message 5 of 9
You can use late binding to invoke methods on the AcadApplication without having to reference the COM type libraries.
for example:
object oApp = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
// Call the Quit() method of the AcadApplication object:
oApp.GetType().InvokeMember("QUIT", BindingFlags.InvokeMethod, null, oApp, null);
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message news:6043527@discussion.autodesk.com...
Hi Terry,
Raul
Message 6 of 9
Thanks Tony for the late binding example. It will do it.
Message 7 of 9
I get the same message as below and as the attached file. Several users here have the same problem. We are using hp Z600 Xenon Quad core with 6GB ram & .5Terra Hdd's & 750 MB Nvidea FX1800 Video cards on Windows XP x64 Operating System
I was told by a reseller that this function has been disabled in Civil 3D and wanted £800 to try & fix it. (.NET software have all been deleted and reloaded from Microsoft website)
This error is reportwed when in the CUI interface and trying to drag & drop other icons into other icon groups. I do not use Ribbon as I do not like it and neither do most of the other users in this company. Classic sytle is best for our use.
I manage 500 cad users here with over £500,000 outlay to Autodesk. I would like a free fix please. I can do anything in Civil 3D 2009 without error messages.
Come on Autodesk what is the problem? Or is it just a way for resellers to make some extra cash?
Message 8 of 9
Whatever reseller told you that is trying to rob you.
This is a bug, plain and simple, and any reseller that tries to sell
you a 'fix' for a bug should be reported to Autodesk.
Supporting AutoCAD 2000 through 2010
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6321611@discussion.autodesk.com...
System
our use.
some extra cash?
Message 9 of 9
Hello, I'm having the same issue when I try to drag and drop a command from the command list into the shortcut keys palette. I'm using AutoCAD 2008 64bit. Any help would be appreciated.
