WinForm/WPF and AutoCAD 2007 & 2011.
Hello!
I have standalone application. With this app I'm startin an AutoCAD 2007.
  const string progID = "AutoCAD.Application.17";
            AcadApplication acApp = null;
            try
                acApp = (AcadApplication)Marshal.GetActiveObject(progID);
            catch
                try
                    Type acType = Type.GetTypeFromProgID(progID);
                    acApp = (AcadApplication)Activator.CreateInstance(acType, true);
                catch
                    MessageBox.Show("Cannot create object of type \"" + progID + "\"");
            if (acApp != null)
                // By the time this is reached AutoCAD is fully
                // functional and can be interacted with through code
                acApp.Visible = true;
                acApp.ActiveDocument.SendCommand(....);
I've added references to the AutoCAD 2007 Type Library and ObjectDBX (2007).
But I want to have my application compatibile with AutoCAD 2011. With detection which AutoCAD is installed I don't have any problems.
But how can I add the references depending on AutoCAD version? I tried to add both, but this is impossible.
I was thinking about dynamically loading assemblies, but how can I then call AutoCAD and SendCommand?
Thanks for the help.
Hallex
Type in the command lIne ACADVER
you will be get a current version of your
AutoCAD installed
With version detection I don't have problems as I said, but thanks.
That's nice tricky command 😉
The question is about assemblies references and differents versions.
Or maybe other question:
How can I send command to the autocad without declaring its version? So the code will be compatibile for both AC 2007 and 2011.
