Windows 7 proper place to put code
Hi everyone, I am currently trying to update OS from XP to 7. In the past (XP) I was able to put my code just about any place in the Program directory. Win 7 on the other hand is giving me all kinds of write errors.
Any advice/help would be greatly appreciated.
Thank you,
-J
arcticad
 C:\Users\<LOGIN NAME>\ should be a safe place. I'd create a folder in this directory.
(defun botsbuildbots() (botsbuildbots))
Thank you arctcad for a quick response,
I was hopping that thier is a place that will allow me to hardoce the path. Also a place that the average user can not temper with.
If anyone uses other directorise please advice,
Thank you in advance,
-J
There is a magical folder that's called program data. Thats the place where you should put your data files. Or you can put in C:\Users\<user>\AppData\Roaming
Kind regards,
Irvin
Thank you for the reply Irvin. Can you please tell me where the "program data" location is, I am having a little diffeculty with Win 7.
Thank you,
-J
arcticad
it's a hidden folder.
C:\ProgramData
http://www.intowindows.com/how-to-hideunhide-a-file-or-folder-in-windows-7/
Thank you Arcticad, taht was exactly what i was looking for. 🙂
