Width of DBText
Width of DBText
youssefGC
Message 1 of 9
Width of DBText
youssefGC
Hello everyone,
Normally the width of the text depends on the number of characters, I need a method to know the width of a DBText in my drawing, is it possible to do this by programming?
using (DBText Txt = new DBText())
                Txt.TextString = "I need to read the width of this text";
Thank you.
Replies (8)
Message 2 of 9
_gile
You can P/Invoke acedTextBox as shown in the DBTextExtension class (GetTextBoxCorners method) from Gile.AutoCAD.Extension library.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 3 of 9
daniel_cadext
AcDbText::getBoundingPoints isn’t in .NET?
you may be able to put the contents in an MText, then
call AcDbMText::getBoundingPoints
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 4 of 9
youssefGC
I use "Extents Box" to calculate the dimensions width height of the text :
public double GetLengthOfText(DBText txt, ObjectId IdOfStyle)
            double width = 0.0, height = 0.0;
            Autodesk.AutoCAD.GraphicsInterface.TextStyle iStyle = new Autodesk.AutoCAD.GraphicsInterface.TextStyle();
            iStyle.FromTextStyleTableRecord(IdOfStyle);
            Extents2d extents = iStyle.ExtentsBox(txt.TextString, true, true, null);
            width = extents.MaxPoint.X - extents.MinPoint.X;
            height = extents.MaxPoint.Y - extents.MinPoint.Y;
            return width * (txt.Height / height);
Message 5 of 9
kerry_w_brown
I use a variation of this :
https://www.theswamp.org/index.php?topic=50493.msg556106#msg556106
Handy for determining the space text will occupy, without necessarily having the Text object.
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 6 of 9
daniel_cadext
That’s pretty slick, you could use that to pre calculate table column widths
Message 7 of 9
kerry_w_brown
Exactly !
Also handy when auto-choosing an Item_Balloon which is a suitable length to use for component 'numbers'
Message 8 of 9
youssefGC
Thank you, but in my case I have to pass a DbText in the argument to take into consideration the change in text height in my main code.
Message 9 of 9
kerry_w_brown
@youssefGC
That's fine, but not obvious from your original question.
