Why my code won't work
dinhthit25
Message 1 of 12
dinhthit25
I want to paint 2 color alternate on every face of a solid3d object, im using Solid3d.SetSubentityMaterial method the code have no error but it won't work can anyone have me. Im using C#.net framework 4.8 at visual studio 2022. Here the code
public class Solid3dMaterialExample
    [CommandMethod("SetTwoColorsToSolid3dFaces")]
    public void SetTwoColorsToSolid3dFaces()
        Document doc = Application.DocumentManager.MdiActiveDocument;
        Database db = doc.Database;
        Editor ed = doc.Editor;
        using (Transaction tr = db.TransactionManager.StartTransaction())
            // Select Solid3d object
            PromptEntityOptions peo = new PromptEntityOptions("\nSelect a Solid3d:");
            peo.SetRejectMessage("\nObject must be a Solid3d.");
            peo.AddAllowedClass(typeof(Solid3d), true);
            PromptEntityResult per = ed.GetEntity(peo);
            if (per.Status != PromptStatus.OK)
                ed.WriteMessage("\nNo valid Solid3d selected.");
                return;
            Solid3d solid3d = tr.GetObject(per.ObjectId, OpenMode.ForWrite) as Solid3d;
            if (solid3d == null)
                ed.WriteMessage("\nFailed to access Solid3d.");
                return;
            // Create two materials with different colors
            ObjectId materialId1 = CreateMaterial(tr, db, "Material1", Color.FromColorIndex(ColorMethod.ByAci, 1)); // Red
            ObjectId materialId2 = CreateMaterial(tr, db, "Material2", Color.FromColorIndex(ColorMethod.ByAci, 3)); // Blue
            // Check and apply alternating materials to the faces
            try
                using (Brep brep = new Brep(solid3d))
                    int faceIndex = 0;
                    foreach (Autodesk.AutoCAD.BoundaryRepresentation.Face face in brep.Faces)
                        try
                            SubentityId faceId = face.SubentityPath.SubentId;
                            if (faceId.Type == SubentityType.Face) // Check the type of Subentity
                                // Apply alternating materials
                                ObjectId materialToApply = (faceIndex % 2 == 0) ? materialId1 : materialId2;
                                solid3d.SetSubentityMaterial(faceId, materialToApply);
                                ed.WriteMessage($"\nMaterial applied to face {faceIndex}.");
                                faceIndex++;
                        catch (System.Exception ex)
                            ed.WriteMessage($"\nError applying material to face: {ex.Message}");
                ed.WriteMessage($"\nError processing Brep: {ex.Message}");
            tr.Commit();
    private ObjectId CreateMaterial(Transaction tr, Database db, string materialName, Color color)
        // Create a new material
        Material material = new Material
            Name = materialName
        // Add the material to the MaterialDictionary
        DBDictionary materialDict = (DBDictionary)tr.GetObject(db.MaterialDictionaryId, OpenMode.ForWrite);
        ObjectId materialId = materialDict.SetAt(materialName, material);
        tr.AddNewlyCreatedDBObject(material, true);
        return materialId;
Replies (11)
Message 2 of 12
kerry_w_brown
Is the code hitting this line ??
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 3 of 12
dinhthit25
i dubugging it and this line appear:
Autodesk.AutoCAD.BoundaryRepresentation.Exception: 'Exception of type 'Autodesk.AutoCAD.BoundaryRepresentation.Exception' was thrown.'
i hope i can print 2 color alternate on every face of a solid3d object but won't
Message 4 of 12
kerry_w_brown
On what line was the error reported ?
What was the actual error ?
How complex was the solid you are testing with ?
Any other information you can think of that may help resolve the issue ?
Message 5 of 12
kerry_w_brown
This looks suspect. Are you sure this block of code is correct ?
            Name = materialName
How much help did you get from an AI source ?
Message 6 of 12
dinhthit25
sorry for my deficiency,
I use ai on private ObjectId CreateMaterial class
i do not check that code you sent thoroughly
when i debug, this happen
this happen when i chose a solid3d object
and this is the testing solid(it quite complex)
and finally im changing it from using Solid3d.SetSubentityColor method to using  Solid3d.SetSubentityMaterial method
Message 7 of 12
kerry_w_brown
I'd close that  drawing . . . it looks like about 30 solid components.
Do your initial development on a simple solid ( or perhaps one of the bracing plate components )
You are currently catching System Exceptions.  Perhaps change that to
Message 8 of 12
_gile
As I replied you in another thread, you need to use the Brep constructor which takes a FullSubentityPath as argument to be able to access to the Solid3d Subentities (Faces here).
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 9 of 12
dinhthit25
im doing it, but i thinks my FullSubentityPath wrong and i am trying to fix it, thanks again for your advice
Message 10 of 12
_gile
You're not doing it in the code you posted in the thread:
I showed you how to do it here.
Gilles Chanteau
GileCAD
GitHub
Message 11 of 12
dinhthit25
thanks you i will watch it agains
Message 12 of 12
dinhthit25
Thanks you, now i can put both color in 1 solid3d object
