Which would be preferred and why?
StormyC
StormyC
I've coded the following to obtain a list of layouts within open drawings.  The purpose is to obtain a full list of layout object ids so I can use them later.  I was wondering which would be best to use considering there will be 50ish drawings each with 5 layouts. By 'best' I mean 'most efficient' and 'best practice'.
Alternatively is there an even better way to obtain a list of layout object ids???
Dim qDLs As IEnumerable(Of ObjectId) = _
From ll In acBlkTbl _
  Let f = CType(ll.GetObject(OpenMode.ForRead), BlockTableRecord) _
  Where f.IsLayout = True And f.Name <> "*MODEL_SPACE"
Select ObjID = f.LayoutId
Dim DwgLayoutIds1 = qDLs.ToList()
 And;
Dim DwgLayoutIds2 As New ObjectIdCollection
For Each BlkTblRecId As ObjectId In acBlkTbl
Dim BlkTablRec As BlockTableRecord = acTrans.GetObject(BlkTblRecId, OpenMode.ForRead)
If BlkTablRec.IsLayout And BlkTablRec.Name <> "*MODEL_SPACE" Then                               DwgLayoutIds2.Add(BlkTablRec.LayoutId)
End If Next
(Apologies for the code formatting)
StormyC
Here is yet another method of getting those layout object ids.
Dim acLayoutDict As DBDictionary = AcDb.LayoutDictionaryId.GetObject(OpenMode.ForRead, False)
Dim iLayoutDict As IDictionary = acLayoutDict
Dim LayoutIds As ICollection = iLayoutDict.Values
Dim DwgLayoutIds3 As New ObjectIdCollection
For Each obj As ObjectId In LayoutIds
  Dim LayObj As Layout = acTrans.GetObject(obj, OpenMode.ForRead, False)
  If LayObj.LayoutName <> "Model" Then
    DwgLayoutIds3.Add(obj)
  End If
Next
I pulled this together using a post from Tony Tanzillo regarding casting a DBDictionary to an IDictionary.
Any opinions anyone?  Or am I still missing the simplest way of getting the layout objectids, excluding model space...?
_gile
By my side, I'd directly step through the Layout Dictionary
            ObjectIdCollection layouts = new ObjectIdCollection();
            using (Transaction tr = db.TransactionManager.StartTransaction())
                DBDictionary dict = (DBDictionary)tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead);
                foreach (DBDictionaryEntry entry in dict)
                    if (entry.Key != "Model")
                        layouts.Add(entry.Value);
                tr.Commit();
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
StormyC
Thanks Gile,
I had trouble getting the .values out of the dictionary - I was getting the 'Protected' error.
I will give your code a try.
_gile
In fact, the way I prefer would be using F#:
let dict = tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead) :?> DBDictionary
let layouts = [for e in dict do if e.Key <> "Model" then yield e.Value]
Gilles Chanteau
GileCAD
GitHub
