Which include defines AcadBlockReference, AcadCircle, etc.?
So, I have had success now opening an AutoCAD instance and document from an external program through ActiveX/COM.
I have been able to add all sorts of objects and even insert a block.
Everything is going great. Except I need to be able to store a reference to the objects that I have now figured out how to add. And this is where the trouble comes up again. The reference documents are really good, with one MASSIVE exception. They don't tell you where the classes can be found. I cannot find anywhere that states what I need to reference or include to use the AcadEntity and its child classes.
So, once again, if I could get some help in determining which dll or tlb I need to reference and which using statement I need to add so that I can use these in my program I would be very grateful.
Thank you,
Michael
Ed__Jobe
Typically, you would use the Object Browser in Visual Studio to examine the object tree. For ActiveX, there is a help system located here. If you install the VBA enabler, it installs acadauto.chm, which I prefer over online help.
The ActiveX objects are usually prefixed with Acad?? as opposed to ac??. They are included in the interop libraries you already referenced.
Ed
How to post your code.
Ed,
Thank you.
Looking into what you provided I found that I needed to add "using Autodesk.AutoCAD.Interop.Common;" to my includes.
Michael
Ed__Jobe
You might also want to include a line that sets the app object.
using AcadApp = Autodesk.AutoCAD.ApplicationServices.AcadApplication;
Ed
I will do that.
Thank you
