What's wrong with the TrayItem's event?
There happens nothing when I click on the trayitem.
[CommandMethod("Test")]
static public void test()
TrayItem item=acadApp.StatusBar.TrayItems[0];
item.MouseDown+=new StatusBarMouseDownEventHandler(item_MouseDown);
private static void item_MouseDown(object sender, StatusBarMouseDownEventArgs e)
System.Windows.Forms.MessageBox.Show("Tray Item Clicked");
You can only sink the events for the tray items that you created:
public class TestStatusBarPane
[CommandMethod("PANETEST")]
public void DoIt()
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("Application
Statusbar \n");
StatusBar sb = Application.StatusBar;
// add a new pane
Pane newPane = new Pane();
newPane.Text = "Hello";
newPane.ToolTipText = "Hello Tip";
newPane.Visible = true;
newPane.MinimumWidth = 40;
newPane.Style = PaneStyles.Normal;
newPane.MouseDown += new
StatusBarMouseDownEventHandler(paneMouseDown);
sb.Panes.Add(newPane);
PaneCollection panes = sb.Panes;
foreach (Pane p in panes)
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("Pane
-- {0}\n", p.Text);
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("Document
Statusbar \n");
sb = Application.DocumentManager.MdiActiveDocument.StatusBar;
panes = sb.Panes;
-- {0}\n", p.Text);
static void paneMouseDown(Object o, StatusBarMouseDownEventArgs e)
Pane p = (Pane) o;
on Click-- {0} {1}\n", p.Text, e.Button);
static void trayMouseDown(Object o, StatusBarMouseDownEventArgs e)
TrayItem ti = (TrayItem) o;
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("Tray
on Click-- {0} {1}\n", ti.ToolTipText, e.Button);
ti.CloseBubbleWindows();
static void bubbleClosed(Object o,
TrayItemBubbleWindowClosedEventArgs e)
TrayItemBubbleWindow bubble = (TrayItemBubbleWindow) o;
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("Bubble
'{0}' closed on Click -- {1}\n", bubble.Title, e.CloseReason);
public class TestStatusBarTray
static TrayItem oneNewTi = null;
[CommandMethod("TRAYTEST")]
public void DoIt()
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("Status
Bar Tray Item test \n");
TrayItemCollection tis = sb.TrayItems;
TrayItem oneTi = null;
foreach (TrayItem ti in tis)
-- {0}\n", ti.ToolTipText);
oneTi = ti;
if (oneTi != null && oneNewTi == null)
oneNewTi = new TrayItem();
oneNewTi.Visible = true;
oneNewTi.Icon = oneTi.Icon;
oneNewTi.ToolTipText = "copy of " + oneTi.ToolTipText;
tis.Add(oneNewTi);
oneNewTi.MouseDown += new
StatusBarMouseDownEventHandler(trayMouseDown);
TrayItemBubbleWindow bubble = new TrayItemBubbleWindow();
bubble.Text = "Bubble Text";
bubble.Title = "Bubble Title";
bubble.HyperLink = "http://google.com";
bubble.HyperText = "Cool site";
oneNewTi.ShowBubbleWindow(bubble);
bubble.Closed += new
TrayItemBubbleWindowClosedEventHandler(bubbleClosed);
wrote in message news:4894583@discussion.autodesk.com...
Albert,
Excellent example, thanks. Having played with this for a few minutes,
I'm really intrigued by the Popup pane style. It looks as though it's
meant to attach a menu item to. Any chance you could make a simple
example showing a menu popup and a click handler on a menu item? (or
would the menu events handle the click?)
Something like a menu with "Say Hello" and an event handler of MsgBox
("Hello world")? I can run with it from there.
Thanks in advance for your help, and thanks for everything you do here
for us,
-Danny Polkinhorn
WATG
Honolulu
PS: Here's the VB port (as well as I can do it, watch for wrapping)...
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Windows
Public Class TestStatusBarPane
_
Public Sub DoIt()
Statusbar " + ControlChars.Lf)
Dim sb As StatusBar =
Autodesk.AutoCAD.ApplicationServices.Application.StatusBar
' add a new pane
Dim newPane As New Pane
newPane.Text = "Scale: 1/8'' = 1'-0''"
newPane.ToolTipText = "Default Scale"
newPane.Visible = True
newPane.Style = PaneStyles.PopUp
AddHandler newPane.MouseDown, AddressOf paneMouseDown
Dim panes As PaneCollection = sb.Panes
Dim p As Pane
For Each p In panes
-- {0}" + ControlChars.Lf, p.Text)
Next p
panes = sb.Panes
For Each p In panes
Next p
End Sub 'DoIt
Shared Sub paneMouseDown(ByVal o As Object, ByVal e As
StatusBarMouseDownEventArgs)
Dim p As Pane = CType(o, Pane)
-- {0} {1}, Style: " + ControlChars.Lf, p.Text, e.Button, p.Style.ToString)
End Sub 'paneMouseDown
Shared Sub trayMouseDown(ByVal o As Object, ByVal e As
Dim ti As TrayItem = CType(o, TrayItem)
on Click {0} {1}" + ControlChars.Lf, ti.ToolTipText, e.Button)
End Sub 'trayMouseDown
Shared Sub bubbleClosed(ByVal o As Object, ByVal e As
TrayItemBubbleWindowClosedEventArgs)
Dim bubble As TrayItemBubbleWindow = CType(o, TrayItemBubbleWindow)
'{0}' closed on Click -- {1}" + ControlChars.Lf, bubble.Title,
e.CloseReason)
End Sub 'bubbleClosed
Public Class TestStatusBarTray
Private Shared oneNewTi As TrayItem = Nothing
_
Public Sub DoIt()
Bar Tray Item test " + ControlChars.Lf)
Dim sb As StatusBar = Application.StatusBar
Dim tis As TrayItemCollection = sb.TrayItems
Dim oneTi As TrayItem = Nothing
Dim ti As TrayItem
For Each ti In tis
-- {0}" + ControlChars.Lf, ti.ToolTipText)
oneTi = ti
Next ti
If Not (oneTi Is Nothing) And oneNewTi Is Nothing Then
oneNewTi = New TrayItem
oneNewTi.Visible = True
tis.Add(oneNewTi)
AddHandler oneNewTi.MouseDown, AddressOf trayMouseDown
End If
Dim bubble As New TrayItemBubbleWindow
AddHandler bubble.Closed, AddressOf bubbleClosed
End Sub 'DoIt
End Class 'TestStatusBarTray
End Class 'TestStatusBarPane
hmm... i'm frustrated, i'm using this code and there's no bubble coming up... does anyone know why?
