What about "LispFunction" definition in c# ?
erictonneau6438
erictonneau6438
Hello everyone,
Does the following feature [LispFunction("function_name")] still exist in AutoCAD 2024 references?
Code C#:
[LispFunction("myapp_logon")]
public Object myapp_logon_LispFunction(ResultBuffer rbArgs)
Has it been replaced by something else?
Thank you all
_gile
@erictonneau6438 wrote:
Hello everyone,
Yes, it does.
https://help.autodesk.com/view/OARX/2024/ENU/?guid=OARX-ManagedRefGuide-Autodesk_AutoCAD_Runtime_Lis...
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
erictonneau6438
Thanks a lot !
It seems that the basic "LispFunction" is called now "ListFunctionAttribute", correct ?
erictonneau6438
This doesn't seem to fit my needs...
erictonneau6438
ok, in fact the functionality is still there... but I have compilation errors.
https://help.autodesk.com/view/OARX/2024/ENU/?guid=GUID-3B2760FE-A0DC-4229-AEBE-5CC83290BA95
I think the problem comes from different versions of the .NET framework.
I have to investigate...
_gile
LispFunction (as CommandMethod) is an Attribute defined in the LispFunctionAttribute class (or CommandMethodAttribute class) which derives from the Attribute class.
As far as I know, both LispFunctionAttribute and CommandMethodAttribute are part of the AutoCAD .NET API for as long this API exists.
Gilles Chanteau
GileCAD
GitHub
