VLA-object with no properties and methods
I have compiled a class library that is exposed to com and I can
(setq aa (vla-getinterfaceobject acadobj "ClassLibrary4.NET_Temp"))
_$ (vlax-dump-object aa t)
it returns:
; _NET_Temperature: nil
; No properties
; No methods
T
How do I setup the properties and methods to be able to use them from lisp?
I am still trying to implement:
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dndotnet/html/callcomcomp.asp
Any help would be greatly appreciated.
Mathew
Did you check 'Register for COM Interop' in your
project settings? If not, post your code if it is
not ummmm proprietary.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
"Darcy" wrote in message news:4909625@discussion.autodesk.com...
it returns:
; No properties
; No methods
T
Mathew
I have these attributes:
< assemblykeyfileattribute="">
< assemblytitle="">
< clscompliant="">
< comvisible="">
and a Batch file:
"C:\Program Files\Microsoft Visual Studio .NET 2003\SDK\v1.1\Bin\sn.exe" -k
PhysServer2.snk
"C:\Program Files\Microsoft Visual Studio .NET 2003\SDK\v1.1\Bin\tlbexp.exe"
PhysServer2.dll /out:PhysServer2.tlb
"C:\WINdows\Microsoft.NET\Framework\v1.1.4322\regasm.exe"
/tlb:PhysServer2.tlb PhysSERVER2.dll
2003\SDK\v1.1\Bin\gacutil.exe" /i PhysServer2c.dll
Here is the class. I have checked the 'Register for COM Interop' checkbox.
Public Interface iTemperature
Property Celsius() As Double
Property Fahrenheit() As Double
Function GetCelsius() As Double
Function GetFahrenheit() As Double
End Interface
Public Class NET_Temperature
Implements iTemperature
Private mdblCelsius As Double
Private mdblFahrenheit As Double
Public Property Celsius() As Double _
Implements iTemperature.Celsius
Get
Celsius = mdblCelsius
End Get
Set(ByVal Value As Double)
mdblCelsius = Value
mdblFahrenheit = ((Value * 9) / 5) + 32
End Set
End Property
Public Property Fahrenheit() As Double _
Implements iTemperature.Fahrenheit
Get
Fahrenheit = mdblFahrenheit
End Get
mdblFahrenheit = Value
mdblCelsius = ((Value - 32) * 5) / 9
End Set
End Property
Public Function GetCelsius() As Double _
Implements iTemperature.GetCelsius
GetCelsius = mdblCelsius
End Function
Public Function GetFahrenheit() As Double _
Implements iTemperature.GetFahrenheit
GetFahrenheit = mdblFahrenheit
End Function
End Class
Thanks again.
Matthew
"Tony Tanzillo" wrote in message
news:4909714@discussion.autodesk.com...
it returns:
; No properties
; No methods
T
Mathew
Search MSDN for the ClassInterfaceType and ProgID attributes.
You're missing those, which is required for a class
that is exposed via COM.
"Matthew" wrote in message news:4910016@discussion.autodesk.com...
< assemblytitle="">
< clscompliant="">
< comvisible="">
and a Batch file:
PhysServer2.snk
End Interface
Get
End Get
mdblCelsius = Value
End Set
End Property
Get
End Get
End Set
End Property
End Function
End Function
End Class
Thanks again.
Matthew
it returns:
; No properties
; No methods
T
Mathew
Thanks Tony
I posted to the Microsoft news group as well. Someone over there said that
the Strong Name property page was in the Bata, and they took it out of the
final release.
Matthew
news:4910636@discussion.autodesk.com...
< assemblytitle="">
< clscompliant="">
< comvisible="">
and a Batch file:
PhysServer2.snk
End Interface
Get
End Get
mdblCelsius = Value
End Set
End Property
Get
End Get
End Set
End Property
End Function
End Function
End Class
Thanks again.
Matthew
it returns:
; No properties
; No methods
T
Mathew
