Visual Studio 2010 Express Objectarx Wizard
GeeHaa
GeeHaa
Does anyone know where I can find the objectarx wizard for VS2010 Express? The objectarx wizards I see on the Autodesk Website seem to be for the full version. I found it once and installed it. If I remember right it wasn't called a wizard. It creates  the template needed for a Basic AutoCAD Plugin.
StephenPreston
Are you looking in the right place? Our .NET Wizards (project templates) are hosted on www.autodesk.com/developautocad. Search on that page for "AutoCAD .NET Wizards" (not ObjectARX Wizards).
Cheers,
Stephen Preston
Autodesk Developer Network
kerry_w_brown
The link is broken Stephen.
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
www.autodesk.com/developautocad is the correct link. Any punctuation (period, comma...) after a url text always causes this issue all the time. As this punctuation is automatically included in HTML <a> tag on final preview. It's better to have a space between them.
GeeHaa
Thanks Guys,
I found it - Its all the way at the bottom of the page. I missed it before.
http://usa.autodesk.com/adsk/servlet/index?id=1911627&siteID=123112
mgorecki
I'll have to try the wizard, I was trying to export my own template, but there were issues when I tried to use it.
I set the AcDbMgd and the AcMgd in my references.  I then output a template and the references were still there, but the path was lost.
<The system cannot find the reference specified>.
Is there any way to force the template output to keep the path?
Mark
