Perhaps you don't have any problems because you've never
debugged a managed application.
That's when the commands are not recognized.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
"Joe Sutphin"
wrote in message news:[email protected]...
Evidently not since I don't and I don't have any problems.
Joe ...
"Paul Richardson" wrote in message
You have to or the commands won't be recognized. If you create a project
using the wizard it does it for you though.
"Joe Sutphin" wrote in message
Oops, you should do that, although I never do.
Joe ...
>>First, make sure you have a reference set to acMgd.dll and acDbMgd.dll.
Also set 'copy local' to false for both... Seem to be the original problem.
Next, start a "Class Library" project type.
Then, paste this code in the editor:
Imports Autodesk.AutoCAD.Runtime
Public Class Examples
_
Public Sub Hello()
MsgBox("This is a test")
End Sub
End Class
Build the solution and then netload it into AutoCAD. Type "Hello" at the
command prompt and you should see a dialog box with the message above.
Joe ...
It is possible to use VB 2008 Express With AutoCAD 2009.
I tried the object arx2009 Hello VB sample, I compile it, and i used
Netload, but when i type HELLO at the AutoCAD 2009 command line, it says
that it is not a command, I need Help
Thank You
