Visual Basic 2008 Express and AutoCAD 2009
Message 1 of 11
It is possible to use VB 2008 Express With AutoCAD 2009.
I tried the object arx2009 Hello VB sample, I compile it, and i used Netload, but when i type HELLO at the AutoCAD 2009 command line, it says that it is not a command, I need Help
Thank You
Replies (10)
Message 2 of 11
First, make sure you have a reference set to acMgd.dll and acDbMgd.dll.
Next, start a "Class Library" project type.
Then, paste this code in the editor:
Imports Autodesk.AutoCAD.Runtime
Public Class Examples
_
Public Sub Hello()
MsgBox("This is a test")
End Sub
End Class
Build the solution and then netload it into AutoCAD. Type "Hello" at the
command prompt and you should see a dialog box with the message above.
Joe ...
wrote in message news:[email protected]...
Thank You
Message 3 of 11
Also set 'copy local' to false for both... Seem to be the original problem.
"Joe Sutphin" wrote in message news:[email protected]...
_
Public Sub Hello()
End Sub
End Class
Joe ...
Thank You
Message 4 of 11
Oops, you should do that, although I never do.
Joe ...
"Paul Richardson" wrote in message
_
Public Sub Hello()
End Sub
End Class
Joe ...
Thank You
Message 5 of 11
You have to or the commands won't be recognized. If you create a project using the wizard it does it for you though.
Joe ...
_
Public Sub Hello()
End Sub
End Class
Joe ...
Thank You
Message 6 of 11
Evidently not since I don't and I don't have any problems.
Joe ...
Joe ...
_
Public Sub Hello()
End Sub
End Class
Joe ...
Thank You
Message 7 of 11
Perhaps you don't have any problems because you've never
debugged a managed application.
That's when the commands are not recognized.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
Joe ...
Joe ...
_
Public Sub Hello()
End Sub
End Class
Joe ...
Thank You
Message 8 of 11
So you can set 'copy local' to true and still have the commands run... I cannot. Anyone else able to create
commands without setting 'copy local' to false?
Joe ...
Joe ...
_
Public Sub Hello()
End Sub
End Class
Joe ...
Thank You
Message 9 of 11
I should have mentioned this is only during debugging - Danka!
"Tony Tanzillo" wrote in message news:[email protected]...
Joe ...
Joe ...
_
Public Sub Hello()
End Sub
End Class
Joe ...
Thank You
Message 10 of 11
Thank you very much, now it is working
Message 11 of 11
I just upgraded to Visual Studio 2008. I have found that it wont recognize any of the commands that i compiled with it. I Can debug it great, but i go to install on another machine it doesnt work one bit. Any help would be appreciated.
Using Version AutoCAD 2007,2008,2009. The version doesnt matter. It must be sometihng during the compile. I have tried copying local and not. Its getting frustrating!!
