Veto functionality bug?
Hi all,
Has anyone had any luck calling the Veto method in the DocumentLockModeChanged event? I'm trying to cancel the user's EATTEDIT command for some particular blocks. So in the DocumentLockModeChanged event I check for that command and block and then call e.Veto(). It doesn't error out, but it also doesn't stop the command. I'm wondering if there's a bug with the veto, since I set up an event for DocumentLockModeChangeVetoed and it doesn't hit that after I call veto.
Anyone else run into this? Here's what my code looks like:
void DocumentManager_DocumentLockModeChanged(object sender, DocumentLockModeChangedEventArgs e)
try
if (e.GlobalCommandName == "EATTEDIT" && IsSpecialBlock(e.Document))
// Block the edit
e.Veto();
catch { }
The name of the event is DocumentLockModeChanged.
That is, 'Changed", in the past tense.
How can you veto something that has already happened?
More importantly, this isn't going to work in any case,
because the EATTEDIT dialog has a button that lets
the user select another block.
I was going to suggest using the Managed events on
the Editor (namely Editor.PromptForEntityEnding), but
that event is broken (more like FUBAR) and does not
allow you to selectively prevent selection of objects
(there seems to be some serious problems with the
event and the parameters passed to handlers).
You may be able to do this in native ObjectARX using
the AcEdSSGetFilter::endEntSel() function, but I haven't
actually tried it.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
wrote in message news:4970626@discussion.autodesk.com...
Hi all,
try
// Block the edit
e.Veto();
catch { }
Thanks for the info, Tony. Not sure how I'll resolve it, but at least I know what doesn't work!
Can you give me some more details on the PromptForEntityEnding bug that you
are seeing? I'd like to get it fixed.
albert
"Tony Tanzillo" wrote in message
news:4970767@discussion.autodesk.com...
actually tried it.
Hi all,
try
// Block the edit
e.Veto();
catch { }
The Result parameter of the event argument parameter is
always null, and the RemoveSelectedObject() method doesn't
seem to do what its name suggests. Given those things, the
event is of no use whatsoever, because you can't even find
out what object was selected.
private static void Editor_PromptForEntityEnding(object sender, PromptForEntityEndingEventArgs e)
Editor editor = (Editor) sender;
if( e.Result == null )
editor.WriteMessage("\nPromptForEntityEnding: e.Result == NULL !!!\n");
// This doesn't work at all.
e.RemoveSelectedObject();
return;
// simple test: try to prevent picking of any Circle
ObjectId id = e.Result.ObjectId;
using( Transaction tr = id.Database.TransactionManager.StartTransaction() )
DBObject o = tr.GetObject( id, OpenMode.ForRead );
if( o != null && o is Circle )
"Albert Szilvasy" wrote in message news:4971633@discussion.autodesk.com...
albert
actually tried it.
Hi all,
try
// Block the edit
e.Veto();
catch { }
