Vector and GetPerpendicularVector
Hallo,
i have two vectors, xAxis and yAxis. If yAxis is not perpendicular to xAxis
how do i make it perpendicular? I can get the perpendicular vector of the
xAxis with xAxis.GetPerpendicularVector, but i want to leave the plane the
original Vectors describe.
Does anyone know how to do this?
Roland Feletic
GetPerpendicularVector is only worth something in 2d as there are an infinite number of perpendiculars to a 3d vector.
A bit of a roundabout but this works.
Dim org As New Point3d(0, 0, 0)
Dim xAxis3d As New Vector3d(1, 0, 0)
Dim v3d As New Vector3d(1, 1, 1)
Dim p As New Plane(org, xAxis3d, v3d)
Dim xAxis2d As Vector2d = xAxis3d.Convert2d(p)
Dim yAxis2d As Vector2d = xAxis2d.GetPerpendicularVector()
Dim m As Matrix3d = Matrix3d.PlaneToWorld(p)
Dim yAxis3d As New Vector3d(yAxis2d.X, yAxis2d.Y, 0)
yAxis3d = yAxis3d.TransformBy(m)
Chris Arps
Hi Roland,
you can get the y axis by using something like
yAxis = plane.Normal.CrossProduct(xAxis.Normal).GetNormal(Tolerance.Global);
This should give you a normalised vector perp to the xaxis that remains in the original plane.
Cheers,
Mick.
Message was edited by: Mick Duprez Message was edited by: Mick Duprez to adjust code to correct coordinate system handing.
Thank you,
i will try these steps.
Roland Feletic
Thank you , Mick.
your solution is great 😉
Roland Feletic
schrieb im Newsbeitrag news:5018479@discussion.autodesk.com...
Hi Roland,
the original plane.
Cheers,
Mick.
system handing.
