vba code to vb.net
vba code to vb.net
David_Prontnicki
vba code to vb.net
David_Prontnicki
Hi everyone,
As a learning exercise I am trying to convert a old vba program to vb.net. I am experienced in vb.net and AutoCAD but not with programing Autocad. Hence the learning exercise.
One issue I am having is converting:
Private Sub cmdCreateLayerReport_Click()
'connect or instantiate microsoft word
Set mobjWord = CreateObject("Word.Application")
'make microsoft word visible
mobjWord.Visible = True
'create a new document in microsoft word
Set mobjDoc = mobjWord.Documents.Add
'set header and footer and page layout
With mobjDoc
    ' set page layout to landscape
    .PageSetup.Orientation = wdOrientLandscape
    'set header (drawing path and name)
    .Sections(1).Headers(wdHeaderFooterPrimary).Range.Text = "Layer Report for:  " & Application.Documents(cboDrawingName.Value).Path & "\ " & Application.Documents(cboDrawingName.Value).Name
    'set footer (date created and total layer count)
    .Sections(1).Footers(wdHeaderFooterPrimary).Range.Text = "Date Created: " & Date & vbTab & "Total # of Layers: " & Application.Documents(cboDrawingName.Value).Layers.Count
    'set page numbers
    .Sections(1).Footers(wdHeaderFooterPrimary).PageNumbers.Add wdAlignPageNumberRight
End With
I have converted everything up to the point of:
I cant figure out how to get the layer count to work. (I have adjusted the date)
Any help would be greatly appreciated. Please note that I am using Civil 3D 2016.
David_Prontnicki
I figured it out. I needed to add addition references and Used the code below:
Dim AcadApp As Autodesk.AutoCAD.Interop.AcadApplication
Dim acadDoc As Autodesk.AutoCAD.Interop.AcadDocument
Dim layercount As Integer
AcadApp = GetObject(, "AutoCAD.Application")
acadDoc = AcadApp.ActiveDocument
layercount = acadDoc.Layers.Count
then modified it for the combobox
