VB.NET to select object in paperspace and get Layout name
Sgear
Sgear
Hi
somtime I have 5 Layout or more
is it poseble in VB.NET to select object in paperspace and get Layout name if the Object ar in any Viewport
Regards
Sgear
norman.yuan
You may want to clarify this:
...if the Object ar in any Viewport
When you say "Viewport", I assume it is a Viewport opened on given layout (PaperSpace).
Does "Objects are in any Viewport" mean objects in ModelSpace that can be seen in the Viewport on layout? If so, these objects are in ModelSpace obviously.
Or Do you mean objects actually in the PaperSpace of the layout but happen to sit in the area where a Viewport covers. In this case, why even mention Viewport? It has nothing to do with finding these objects' layout name.
But since you say "select object in paperspace and get Layout name", you can find any entity's layout name (including "Model" for ModelSpace, like this  extension method (not tested):
Public static string GetEntityLayoutName(this ObjectId entId)
  var layoutName="";
  using (var tran = entId.Database.TransactionManager.StartTransaction())
    var ent = (Entity) tran.GetObject(entId, OpenMode.ForRead);
    var owner = (BlockTableRecord)tran.GetObject(ent.OwnerId, OpenMode.ForRead);
    If (owner.IsLayout)
      var layout = (Layout)tran.GetObject(owner.LayoutId, OpenMode.ForRead);
      layoutName = layout.LayoutName;
    tran.Commit();
  return layoutName;
Norman Yuan
Drive CAD With Code
Sgear
Sorry the text was not right
1. the object are in ModelSpace that can be seen in the Viewport on layout
I have large drawing with 10 or more Layout I need to select object in ModelSpace and get the layout name
see attachment
1. if I select Object 1 or 2 I get the name "Layout-A4-name1"
2. if I select Object 3 or 4 I get the name "Layout-A4-name2"
3. if I select Object 5 Nothing happens object 5 can not seen in the Viewport on layout
norman.yuan
So, your goal is to identify/select entities in MOdalSpace which can be seen from a Viewport on a paperspace layout . In this case, how many layouts, how many viewpoers on these layouts does not matter, as long as you can identify entities with a given Viewport (I say this because in your original post you mention "5 Layouts or more" and also emphasized in next reply with "large drawing with 10 or more layouts).
So, basically, for any given paperspace viewport, you need to find its corner coordinates (be it rectangle or non-rectangle) in PaperSpace, and then translate them into ModelSpace coordinate, thus you'll have points for a window/closed polygon in ModelSpace. Now, you can find which entities are enclosed inside it. YOu can use Editor.SelectWindow[CrossingPolygon]() to select entities (you need to switch AutoCAD to ModelSpace), or you can write code to test if an entity is inside the window/plygon.
I do have a post quite a few years ago on how to select Entities in ModelSpace through a paperspace viewport:
https://drive-cad-with-code.blogspot.com/2014/03/selecting-entities-in-modelspace.html
HTH
Norman Yuan
Drive CAD With Code
