Adding attributes to block references in a side database
I'm trying to add a new attribute to all the block references of several drawings. Ideally this would be done as a side database to make it as clean and efficient as possible, however I keep hitting an ewrongdatabase error.
Could anyone please help.
Below is the code for a minimum working example, the code works find for the active document (uncomment all lines ending //comment out #2 and comment  out lines ending //comment out #1 to check) but fails on the btr.AppendEntity(attr); line when trying to run as a side database.
Many thanks
[CommandMethod("MWE", CommandFlags.Session)]
        public static void MWE()
            var filenames = new List<string>();
            filenames.Add("C:\\temp\\test.dwg");
            var attributes = new List<string>();
            attributes.Add("Att1");
            var acDbase = new Database(false, true);
            foreach (var file in filenames) //comment out #1
            //foreach (Document acDoc in Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager) //commentout #2
                acDbase.ReadDwgFile(file, System.IO.FileShare.ReadWrite, false, ""); //comment out #1
                //acDbase = acDoc.Database; //comment out #2
                //acDoc.LockDocument(); //comment out #2
                var acTrans = acDbase.TransactionManager.StartTransaction();
                var acBlkTbl = acTrans.GetObject(acDbase.BlockTableId, OpenMode.ForRead) as BlockTable;
                foreach (var btrId in acBlkTbl)
                    var btr = (BlockTableRecord)acTrans.GetObject(btrId, OpenMode.ForWrite);
                    foreach (var item in attributes)
                        var attr = new AttributeDefinition()
                            Layer = "0",
                            ColorIndex = 0,
                            Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(ColorMethod.ByAci, 0),
                            Tag = item.ToUpper(),
                            Prompt = "Result" + item,
                            TextString = "",
                            Preset = false,
                            TextStyleId = acDbase.Textstyle,//<--   A2010
                            Height = 0.1250,
                            WidthFactor = 0.7500,
                            Justify = AttachmentPoint.MiddleCenter,
                            AlignmentPoint = new Point3d(0, 0.1047, 0),
                            LockPositionInBlock = true,
                            Invisible = true,
                        attr.SetDatabaseDefaults(acDbase);
                        if (false)
                            foreach (ObjectId ObjId in btr)
                                var obj = acTrans.GetObject(ObjId, OpenMode.ForWrite);
                                if (obj is BlockReference)
                                    var acBlock = obj as BlockReference;
                                    AttributeReference attRef = new AttributeReference();
                                    attRef.SetAttributeFromBlock(attr, acBlock.BlockTransform);
                                    acBlock.AttributeCollection.AppendAttribute(attRef);
                                    acTrans.AddNewlyCreatedDBObject(attRef, true);
                        else
                    btr.SynchronizeAttributes();
Additional Functions (SynchroniseAttributes)
public static class ExtensionMethods
        static RXClass attDefClass = RXClass.GetClass(typeof(AttributeDefinition));
        public static void SynchronizeAttributes(this BlockTableRecord target)
            if (target == null)
                throw new ArgumentNullException("target");
            Transaction tr = target.Database.TransactionManager.TopTransaction;
            if (tr == null)
                throw new Autodesk.AutoCAD.Runtime.Exception(ErrorStatus.NoActiveTransactions);
            List<AttributeDefinition> attDefs = target.GetAttributes(tr);
            foreach (ObjectId id in target.GetBlockReferenceIds(true, false))
                BlockReference br = (BlockReference)tr.GetObject(id, OpenMode.ForWrite);
                br.ResetAttributes(attDefs, tr);
            if (target.IsDynamicBlock)
                target.UpdateAnonymousBlocks();
                foreach (ObjectId id in target.GetAnonymousBlockIds())
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(id, OpenMode.ForRead);
                    attDefs = btr.GetAttributes(tr);
                    foreach (ObjectId brId in btr.GetBlockReferenceIds(true, false))
                        BlockReference br = (BlockReference)tr.GetObject(brId, OpenMode.ForWrite);
        private static List<AttributeDefinition> GetAttributes(this BlockTableRecord target, Transaction tr)
            List<AttributeDefinition> attDefs = new List<AttributeDefinition>();
            foreach (ObjectId id in target)
                if (id.ObjectClass == attDefClass)
                    AttributeDefinition attDef = (AttributeDefinition)tr.GetObject(id, OpenMode.ForRead);
                    attDefs.Add(attDef);
            return attDefs;
        private static void ResetAttributes(this BlockReference br, List<AttributeDefinition> attDefs, Transaction tr)
            int error_prot = 0;
            Dictionary<string, string> attValues = new Dictionary<string, string>();
            foreach (ObjectId id in br.AttributeCollection)
                if (!id.IsErased)
                    AttributeReference attRef = (AttributeReference)tr.GetObject(id, OpenMode.ForWrite);
                    try
                        attValues.Add(attRef.Tag,
                          attRef.IsMTextAttribute ? attRef.MTextAttribute.Contents : attRef.TextString);
                    catch
                        try
                            error_prot++;
                            attValues.Add(attRef.Tag + error_prot.ToString(),
                        catch { }
                    attRef.Erase();
            foreach (AttributeDefinition attDef in attDefs)
                attRef.SetAttributeFromBlock(attDef, br.BlockTransform);
                if (attDef.Constant)
                    attRef.TextString = attDef.IsMTextAttributeDefinition ?
                        attDef.MTextAttributeDefinition.Contents :
                        attDef.TextString;
                else if (attValues.ContainsKey(attRef.Tag))
                    attRef.TextString = attValues[attRef.Tag];
                br.AttributeCollection.AppendAttribute(attRef);
                tr.AddNewlyCreatedDBObject(attRef, true);
_gile
You should:
- create a new Database for each file name (within a using statement to insure Dispose is called for each)
- also use a using statement for the transaction
- call Snippet AddNewlyCreatedDBObject() to add the newly created attribute definition.
- not use: if (false) because it will never run
                using (var db = new Database(false, true))
                    db.ReadDwgFile(file, FileOpenMode.OpenForReadAndAllShare, false, "");
                    using (var tr = db.TransactionManager.StartTransaction())
                        var blockTable = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                        foreach (var btrId in blockTable)
                            var btr = (BlockTableRecord)tr.GetObject(btrId, OpenMode.ForWrite);
                                    Layer = "0",
                                    ColorIndex = 0,
                                    TextString = "",
                                    Preset = false,
                                    TextStyleId = db.Textstyle,
                                    Height = 0.1250,
                                    Invisible = true,
                                tr.AddNewlyCreatedDBObject(attr, true);
Gilles Chanteau
GileCAD
GitHub
_gile
I forgot: do not call SetDatabaseDefaults() after having set the layer and color properties.
Gilles Chanteau
GileCAD
GitHub
Thank you for the help, however I am still seeing the same error when running your code. When the code reaches
i get an exception error for eWrongDatabase.
I think these lines are probably missing from your reply at the end of the using transaction/db as well
tr.Commit();
tr.Dispose();
db.CloseInput(true);
db.SaveAs(file, DwgVersion.Current);
_gile
It looks like you cannot set the attribute Layer property before adding it to the Database.
This works for me (tested)
        [CommandMethod("MWE")]
                        var blockTable = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                            if (!(btr.IsLayout || btr.IsFromExternalReference || btr.IsDependent))
                                        TextString = "",
                                        ColorIndex = 0,
                                        Preset = false,
                                        Height = 0.1250,
                                        Invisible = true
                                    attr.Layer = "0";
                        tr.Commit();
Gilles Chanteau
GileCAD
GitHub
Thanks so much more the help! I'm not sure I would have ever spotted that the layer property was the culprit!
