vb.net external open cad drawing
Message 1 of 11
First off, I have working code for opening a cad drawing from an external program.  That is perfect.
What I'm at a loss for is how can I force a drawing that is NOT readonly to open as readonly from outside cad.    I know it's possible within cad, but that doesn't help me.
Can anyone help me out here?
Replies (10)
Message 2 of 11
norman.yuan
How does your external program open a drawing? Without seeing your perfectly working code, I assume it automates AutoCAD via COM API AcadDocuments.Open() method (that is the drawing is still opened in AUTOCAD!)
This method has 2 optional argument to specify if the drawing to be opened as READONLY, and specify a PASSWORD if the drawing is password-protected:
AcadDocuments.Open "C:\....\mydrawing.dwg", True
opens a drawing as read-only.
Norman Yuan
Drive CAD With Code
Message 3 of 11
Actually, no.  I'm using this to open drawings in cad..
System.Diagnostics.Process.Start(dwgpath)
Sounds like i should be doing the other way..   Is there some place I can get a look at working examples?
Message 4 of 11
chiefbraincloud
I have not tried it , but without rewriting all of your existing code, I believe you could just set the ReadOnly Attribute on the file.
Message 5 of 11
Not really an option (mainly because I still want the file to be editable at other times).
Message 6 of 11
chiefbraincloud
So Toggle the Attribute before opening, and toggle it back after closing.  I assumed that went without saying.
Message 7 of 11
chiefbraincloud
I didn't mean my last comment to be condescending, and I agree with Norman, that if you use the built-in COM mechanisms to open a drawing, there is a built-in way to open them read-only, but I just thought I would try to provide an alternative way, that did not require a significant change in your existing code.
I will admit, my suggestion requires that the users of your program have (probably a network based) permission to alter the read/write access to the file in question.  At my company, that problem could come into question under certain circumstances, but not usually when dealing with drawings.
Message 8 of 11
It's alright, everyone should let there inner Tony T out a few times.   🙂
I had briefly thought of doing it that way, but wasn't able to find a way of doing it.   I've since gone the COM route.  Works great (after several google searches and code corrections).
Message 9 of 11
Hallex
Would be interesting to show a result of your code,
Oleg
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 10 of 11
Not much to it, but here you go.  (though for some reason cad crashes if it's used to many times in one session... (5+ i've found))
Used with vanilla 2011
Public Sub Open_DWG ()
        Dim ACAD As Object
        Dim MyAcadPath As String = "dwgpath"
        Dim bReadOnly As Boolean = True
        On Error Resume Next
        ACAD = GetObject(, "autocad.Application")
        If Err.Number <> 0 Then
            Err.Clear()
            ACAD = CreateObject("autocad.Application")
                MessageBox.Show("Failed to start", MessageBoxButtons.OK, MessageBoxIcon.Information)
                GoTo EndOpen
            End If
        End If
        'ACAD.Visible = True
        Err.Clear()
        Dim NewFile As Object = ACAD.Documents.Open(MyAcadPath, bReadOnly)
            MessageBox.Show("Failed to open", MessageBoxButtons.OK, MessageBoxIcon.Information)
        End If
EndOpen:
        ACAD = Nothing
        NewFile = Nothing
    End Sub
Message 11 of 11
Hallex
Thanks so much,
Happy computing 🙂
~'J'~
