VB.net debugging when prompt pause
harryliu3140
harryliu3140
My program tools are VB.net express 2005 with ACAD MEP 2008.
I want to debug a program with GetSelection or GetPoint where the program will pause waiting for user input. The ACAD MEP 2008 will stop running with an "FATAL ERROR: unhandled exception" error when debugging steps to the GetSelection/GetPoint function.
I have no issue when I load the released .dll into ACAD and run. The program like this:
    Public Sub Cmd1() ' This method can have any name
        ' Type your code here
        Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        Dim pntoption As New PromptPointOptions("Please pick a location as the center of the curves")
        Dim pntresult As PromptPointResult
        Dim Opts As New PromptSelectionOptions()
        Opts.SingleOnly = True
        Opts.MessageForAdding = "Select a curve entity"
        Dim res As PromptSelectionResult = ed.GetSelection(Opts)
        If res.Status = PromptStatus.Error Then
            Return
        End If
        Dim SS As Autodesk.AutoCAD.EditorInput.SelectionSet = res.Value
I search in Discussion Groups seem nobody encountered this problem. The error also happen in ACAD MEP 2010.
Hope some know how to get arround.
Thanks.
chiefbraincloud
There is nothing glaring at me, and I do not have MEP installed to try to test, so all I could suggest is to wrap everything into one or more Try/Catch blocks to see if you can step through and get an error message instead of a Fatal Error.
harryliu3140
That's just what I need to do.
You can see I'm a beginner of VB.net. I haven't realized Try/Catch is so useful.
Your help is so appreciated.
Thank you.
