VB.NET block with attributes problem
Hi everyone,
I'm trying to work with block + attributes, I can create it but if I insert it by .net hte block don't have attributes, if I
insert it manually the attributes are ok why?
<CommandMethod("AddingAttributeToABlock")>
            Public Sub AddingAttributeToABlock()
                ' Get the current database and start a transaction
                Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
                Dim acCurDb As Database = acDoc.Database
                Dim blkRecId As ObjectId = ObjectId.Null
                Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                    ' Open the Block table for read
                    Dim acBlkTbl As BlockTable
                    acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                    If Not acBlkTbl.Has("CircleBlockWithAttributes") Then
                        Using acBlkTblRec As New BlockTableRecord
                            acBlkTblRec.Name = "CircleBlockWithAttributes"
                            ' Set the insertion point for the block
                            acBlkTblRec.Origin = New Point3d(0, 0, 0)
                            ' Add a circle to the block
                            Using acCirc As New Circle
                                acCirc.Center = New Point3d(0, 0, 0)
                                acCirc.Radius = 2
                                acBlkTblRec.AppendEntity(acCirc)
                                ' Add an attribute definition to the block
                                Using acAttDef As New AttributeDefinition
                                    acAttDef.Position = New Point3d(0, 0, 0)
                                    acAttDef.Verifiable = True
                                    'acAttDef.Visible = False
                                    acAttDef.Prompt = "Door #: "
                                    acAttDef.Tag = "Door#"
                                    acAttDef.TextString = "DXX"
                                    acAttDef.Height = 1
                                    acAttDef.Justify = AttachmentPoint.MiddleCenter
                                    acAttDef.LockPositionInBlock = True
                                    acBlkTblRec.AppendEntity(acAttDef)
                                    acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForWrite)
                                    acBlkTbl.Add(acBlkTblRec)
                                    acTrans.AddNewlyCreatedDBObject(acBlkTblRec, True)
                                End Using
                            End Using
                            blkRecId = acBlkTblRec.Id
                        End Using
                    End If
                    Dim pPtRes As PromptPointResult
                    Dim pPtOpts As PromptPointOptions = New PromptPointOptions("")
                    '' Prompt for the start point
                    pPtOpts.Message = vbLf & "Enter the point: "
                    pPtRes = acDoc.Editor.GetPoint(pPtOpts)
                    Dim ptStart As Point3d = pPtRes.Value
                    '' Exit if the user presses ESC or cancels the command
                    If pPtRes.Status = PromptStatus.Cancel Then Exit Sub
                    ' Insert the block into the current space
                    If blkRecId <> ObjectId.Null Then
                        Using acBlkRef As New BlockReference(ptStart, blkRecId)
                            Dim acCurSpaceBlkTblRec As BlockTableRecord
                            acCurSpaceBlkTblRec = acTrans.GetObject(acCurDb.CurrentSpaceId, OpenMode.ForWrite)
                            acCurSpaceBlkTblRec.AppendEntity(acBlkRef)
                            acTrans.AddNewlyCreatedDBObject(acBlkRef, True)
                        End Using
                    End If
                    ' Save the new object to the database
                    acTrans.Commit()
                    ' Dispose of the transaction
                End Using
            End Sub
        End Class
norman.yuan
Different from VBA/COM API used for inserting block reference (Model[Paper]Space.InsertBlock(....), if you have ever programmed in AutoCAD VBA, in Acad .NET API/ObjectARX API, you need to write code the add AttributeReference to the BlockReference explicitly. Something like:
'' Create new block reference here
'' Append block reference into space
'' Add block reference to Transaction
'' Create attributereference
For Each id As ObjectId in [theBlockTableRecord]
    If id.ObjectClass.DxfName.ToUpper()="ATTDEF" Then
        Dim attDef=DirectCast(trans.GetObject(id, OpenMode.ForRead), AttributeDefinition)
        If Not attDef.Constant Then
            Dim att =New AttributeReference()
            att.SetAttributeFromBlock(attDef, [blkRef].BlockTransform)
            att.TextString="zzzzzzzz"
            [blkRef].AttributeCollection.AppendAttribute(att)
            trans.AddNewlyCreatedObject(att, True)
        End If
    End If
Next
trans. Commit()
HTH
Norman Yuan
Drive CAD With Code
twmerren
Your code is setting attribute visibility to false.  Set to true and it should be visible.
norman.yuan
@twmerren , what do you talk about? The OP's code not creating and adding AttributeReference to the BlockReference's AttributeCollection is the reason. No having AttributeReference created, how/where the OP's code can set Visible property? I think you must mis-read the OP's code where a line of code setting AttributeDefinition(!)'s Visible property, which is commented out.
Norman Yuan
Drive CAD With Code
