Using file explorer for a plugin
Aprucka
Aprucka
I am creating a plugin which will allow a user to create a drawing automatically based upon a json file. I would like to use a file explorer for the user to select the json file, in the same way that the NETLOAD command works. I was not able to find any sample code for this in the dev guide, is it possible? If so, how?
Thank you!
Aprucka
Just to clarify, I am coding the plugin in C#
David_Prontnicki
Where and when do you want the "file explorer" to show up? Meaning is this from a command in AutoCAD and is it part of a larger project? If its within a larger program loaded into AutoCAD you can use the below function to get the full path and filename of the JSON file.
Public Function SelectJsonFile() As String Implements IFileServices.SelectJsonFile
        Dim JsonFileNameAndLocation As String = "Please select an JSON .json file..."
        Try
            Dim selectJsonFileDialog As New OpenFileDialog With {
                        .Title = "Select JSON File:",
                        .Filter = "JSON (*.json)|*.json",
                        .CheckFileExists = True,
                        .Multiselect = False,
                        .FilterIndex = 2,
                        .RestoreDirectory = True
            If selectJsonFileDialog.ShowDialog() <> DialogResult.Cancel Then
                JsonFileNameAndLocation = IO.Path.GetFullPath(selectJsonFileDialog.FileName)
            End If
        Catch ex As Exception
            'Message omited on purpose
        End Try
        Return JsonFileNameAndLocation
    End Function
 This is VB but can easily be converted online.
Aprucka
Yes, part of a larger project. I want to load a dll for a plugin I have made which has the code to parse a json into a given autocad drawing, then the plugin asks for a file and brings up the file explorer, before taking the path given in the file explorer and parsing it as a string in the code.
David_Prontnicki
See above...
Aprucka
Thanks!
