Used only fixed hatch pattern in drawing.
I got one requirement that in autocad drawing I just want used specific hatch pattern instead of using all.
If hatch pattern other than the given list it shows error and show the name of the hatch pattern.
Please suggest me the way to do this.
Alexander.Rivilis
Easiest way is provide (i.e. edit) acad.pat and acadiso.pat and leave only patterns you may to use. With help of AutoCAD .NET API it will be difficult problem.
Facebook | Twitter | LinkedIn
Expert Elite Member
