Upgrading Plugin to .Net 8.0
My_Civil_3D
Message 1 of 12
My_Civil_3D
Hi All
I have Followed a guide i found here to Upgrade my Plugin to Autocad 2025. I am having issues with Winforms.
Normally when starting a project (.class Library) you can add winforms to it. After Upgrading My Project and Even by Starting a New Project i dont see the Option to add Winforms anymore? am i missing something here?
another question is do i have to upgrade to .Net 8.0?
Civil 3D Certified Professional
Replies (11)
Message 2 of 12
_gile
The first "PropertyGroup" element of your project SDK have to contain this element:
<UseWindowsForms>true</UseWindowsForms>
So that your classes can use System.Windows.Forms and the classes should be decored with the SupportedOSPlatform attribute:
[SupportedOSPlatform("windows")]
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 3 of 12
My_Civil_3D
I Have Added your Line and i Now Get this Error:
i am unsure of how to do this:
Message 4 of 12
_gile
Did you add:
to the first PropertyGroup element of your project SDK? (double click on the project in the Solution Explorer to open it).
Gilles Chanteau
GileCAD
GitHub
Message 5 of 12
ActivistInvestor
I upgraded a WinForms project recently, and here is what I did to include WinForms support, in addition to adding the required assemblies:
 <PropertyGroup>
   <TargetFramework>net8.0-windows</TargetFramework>
   <ImplicitUsings>disable</ImplicitUsings>
   <Nullable>disable</Nullable>
 </PropertyGroup>
I haven't used the SupportedOSPlatform attribute anywhere in the project.
Message 6 of 12
ActivistInvestor
See my (misdirected) reply to @_gile. I haven't needed to use the SupportedOSPlatform attribute in my project, but I did disable the analyzers that warn about platform-dependent code.
Message 7 of 12
My_Civil_3D
i manged to get it to work by manually adidng :
"<UseWindowsForms>true</UseWindowsForms>"
another issue i am facing is with Mysql. i am getting an error saying that its not supported on this platform. first i had to change to Microsoft.dta.SqlClient but when i build my plugin the Microsoft.dta.SqlClient .dll isnt buidlign with the rest of the plugin files. Where previously before the upgrade to dotnet 8.0 i had no issues. am i missing something here?
Message 8 of 12
_gile
This is what @ActivistInvestor and I have been advocating since the start of this discussion.
You can see this topic.
Gilles Chanteau
GileCAD
GitHub
Message 9 of 12
My_Civil_3D
Seems Like there is Still an Issue, i can see the Winforms under the Add window but when clicking on it, it doesnt add a new form
Message 10 of 12
My_Civil_3D
at this point i want to pull out my hair. why cant there just be a .Net 8.0 Template when you create a new project why do you have to always upgrade the project first? i only see .net 4.8 on my target projects i always have to upgrade the project why is that?
Message 11 of 12
_gile
You can find an AutoCAD Project Template for AutoCAD 2025 (AutoCAD R25 Csharp Project Template) on this page. You'll have to edit the template files as explained in the "README" and, to reference Windows Forms, add: <UseWindowsForms>true</UseWindowsForms> to the first PropertyGroup node of the .csproj file.
Gilles Chanteau
GileCAD
GitHub
Message 12 of 12
My_Civil_3D
thank you sir
