Unzip zip resources file
Amremad
Amremad
hello all
i have an resources file called file.zip
to unzip it i must copy it to hard disk  and i have no problem to copy outside it and unzip it directly using ZipFile class
but my question how can i zip it without copy it , i mean using memory stream
i begin from this line but i can't to complete my code to send the stream to ZipFile
            string resource = "Installer.Resources.myFile.zip";
            System.Reflection.Assembly a = System.Reflection.Assembly.GetExecutingAssembly();
            Stream resFilestream = a.GetManifestResourceStream(resource);
            //ZipArchive archive = ZipFile.OpenRead(resFilestream);
OpenRead must give it an string path to can read the archive , but i need to use the stream variable to can unzip some contains not all in this archive.
i hope my question is clear 🙂
moogalm
Autodesk Support
Autodesk Support
If I understand correctly, you are looking for reading entries in-memory of an archive.
For example, I have .zip file which wraps a *.txt file.
 static void Main(string[] args)
            using (FileStream zipToOpen = new FileStream(@"D:\dotnetsnips\inmemroryArchive\reader.zip", FileMode.Open))
                using (ZipArchive archive = new ZipArchive(zipToOpen, ZipArchiveMode.Read))
                    foreach (ZipArchiveEntry entry in archive.Entries)
                        if (entry.FullName.EndsWith(".txt", StringComparison.OrdinalIgnoreCase))
                            using (StreamReader reader = new StreamReader(entry.Open()))
                                Console.WriteLine(reader.ReadLine());
