Unit one Solid3D with Another Solid3D - BooleanOperationType.BoolUnite
Been scratching my head on this one. I think I have eveything correct but it's not working, see below.
Dim F3D As New Solid3d 'these have been assigned a Solid3D
Dim addSolid as New Solid3d 'these have been assigned a Solid3D
F3D.BooleanOperation(BooleanOperationType.BoolUnite, addSolid)
If you see anything wrong, please let me know. Thanks.
Hallex
Try this code, tested on A2010 only
        <CommandMethod("u3")> _
        Public Sub UnionTestCommand()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim ename1 As Entity
            Dim ename2 As Entity
            Dim id1 As ObjectId
            Dim id2 As ObjectId
            ' Select a solids
            Dim peo As New PromptEntityOptions(vbLf & "Select a first solid ")
            peo.SetRejectMessage(vbLf & "Must be solid3d object...")
            peo.AddAllowedClass(GetType(Solid3d), True)
            Dim per As PromptEntityResult = ed.GetEntity(peo)
            If per.Status <> PromptStatus.OK Then
                Return
            End If
            id1 = per.ObjectId
            peo = New PromptEntityOptions(vbLf & "Select second solid ")
            per = ed.GetEntity(peo)
                Return
            End If
            id2 = per.ObjectId
            Dim tr As Transaction = db.TransactionManager.StartTransaction()
            Using tr
                ename1 = TryCast(tr.GetObject(id1, OpenMode.ForRead, False), Entity)
                If ename1 Is Nothing Then Return
                ename2 = TryCast(tr.GetObject(id2, OpenMode.ForRead, False), Entity)
                If ename2 Is Nothing Then Return
                Dim sol1 As Solid3d = TryCast(ename1, Solid3d)
                Dim sol2 As Solid3d = TryCast(ename2, Solid3d)
                sol1.UpgradeOpen()
                sol2.UpgradeOpen()
                ' This will merge the geometry of the input solid sol1
                ' into the geometry of solids[0] and then erase the geometry of
                ' the input solid sol2
                sol1.BooleanOperation(BooleanOperationType.BoolUnite, sol2)
                ' We should delete sol2 otherwise we leave a solid with
                ' degenerate geometry (i.e. zero geometry) in the database
                ' and that could cause issues
                sol2.Erase()
                tr.Commit()
            End Using
        End Sub
 See this article for more
http://adndevblog.typepad.com/autocad/2012/07/solids-created-with-booleanoper-may-crash-autocad-on-s...
It did not work, see below. It breaks right after "MsgBox("2"). FYI, I'm using AcadCad 2014
&nbsp;
&nbsp;
Dim ed As Editor = AcadDoc.Editor
Dim id1 As ObjectId
Dim id2 As ObjectId
id1 = F3D.ObjectId 'F3D &amp; addSolid are already "Solid3D" at this point.
id2 = addSolid.ObjectId 'F3D &amp; addSolid are already "Solid3D" at this point.
MsgBox("1")
Using tr
MsgBox("2")
MsgBox("3")
MsgBox("4")
MsgBox("5")
MsgBox("6")
MsgBox("Volume: " + sol1.MassProperties.Volume.ToString)
MsgBox("7")
sol1.UpgradeOpen()
MsgBox("8")
sol2.UpgradeOpen()
MsgBox("9")
MsgBox("10")
sol2.Erase()
MsgBox("11")
tr.Commit()
End Using
&nbsp;
Balaji_Ram
I tried the code snippet that Hallex shared in AutoCAD 2014 and it worked fine.
If you continue to have this issue, can you please provide the sample project and the drawing for me to reproduce the behavior ?
Balaji
Developer Technical Services
Autodesk Developer Network
