Union of Region using C# .NET
artillis_prado
artillis_prado
And I want to use the above union command for more than 2000 regions. I can do it manually, but I would like to know how to do it using the API.
Jeff_M
region.BooleanOperation(BooleanOperationType.BoolUnite, otherregion);
This is what I use to unite many regions:
                var regions = Region.CreateFromCurves(polys);
                var overall = new DBObjectCollection();
                foreach (Region reg in regions)
                    try
                        regions.Remove(reg);
                        foreach (Region x in regions)
                            if(!x.IsNull)
                                reg.BooleanOperation(BooleanOperationType.BoolUnite, x);
                        if (!reg.IsNull)
                            overall.Add(reg);
                    catch { }
artillis_prado
My question is whether there is a way to handle a larger quantity, like 2000, 3000, or 4000, because the way I am doing it now takes a long time.
