Transform Region
Transform Region
SRSDS
Advisor Advisor
Transform Region
SRSDS
I need regions from an xreference.
How can I transform them to the WCS?
region.TransformBy(XrefTransformMatrix) doesn't give a value.
edit: I'm guessing I need to change it to a polyline, transform the polyline, then convert it back to a region.
I need to deterimine if the region contains a point using brep
_gile
Wouldn't it be simpler to transform the point with the inverse transformation matrix?
Gilles Chanteau
GileCAD
GitHub
SRSDS
Thank you. Yep. 🙂
