There is a bug when using Editor.GetPoint or Editor.Drag while holding down the Shift key.
qoreodlf37
qoreodlf37
When using Editor.GetPoint or Editor.Drag, holding down the Shift key for a few seconds can cause it to return a value even without a mouse click.
It retuns PromptStatus.OK and a randome point. The point isn't even near the mouse cursor.
Is this a bug?
daniel_cadext
Long press seems to toggle ORTHOMODE.  (getpoint) in lisp doesn’t exit for me
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
qoreodlf37
Yes, I press Shift key to toggle ORTHOMODE and to pick other point. But it dosen't toggle to ORTHOMODE , return random point.
ActivistInvestor
Are you dragging a rubber band cursor from a base point when you do this?
qoreodlf37
I use this code.
PromptPointOptions ppo = new PromptPointOptions("Messge");
PromptPointResult ppr = ed.GetPoint(ppo);
if (ppr.Status == PromptStatus.OK)
or
ppo.UseBasePoint = true;
ppo.BasePoint = myPoint;
It happens whether I use ppo.UseBasePoint or not.
