Text Height Update In C Sharp
muckmailer
Message 1 of 46
muckmailer
The following Lisp route will update text by style. Can this be done in C sharp?
I am looking for a c sharp routine that would have an select all so I can make changes to all text in the drawing.
;;  TextHeightUpdate.lsp [command name: THU]
;;  To Update the Height of Text and Mtext in Styles with defined heights,
;;    when height has been changed in Style definition.  Checks Style of all
;;    selected Text/Mtext, and it has a defined height, imposes that on object.
(defun C:THU (/ ss n obj ht)
  (prompt "\nTo Update the Height of fixed-height Text/Mtext,")
  (if (setq ss (ssget '((0 . "TEXT,MTEXT"))))
    (repeat (setq n (sslength ss))
      (setq obj (vlax-ename->vla-object (ssname ss (setq n (1- n)))))
      (if
        (> (setq ht (cdr (assoc 40 (tblsearch "style" (vla-get-StyleName obj))))) 0)
        (vla-put-Height obj ht); then
      ); if
    ); repeat
  ); if
  (princ)
); defun
(vl-load-com)
(prompt "\nType THU for Text Height Update.")
Thank you
Replies (45)
Message 21 of 46
_gile
Oupss!...
Missing links to mtext format code in my previous message >>here<< and >>there<<.
Gilles Chanteau
GileCAD
GitHub
Message 22 of 46
muckmailer
In Statement
var regex = new Regex(@"\\W\d*(\.\d+)?;", RegexOptions.IgnoreCase);
New Regex is missing an assembly reference.
Is there a reference library that  I might be missing?
Thank you,
Message 23 of 46
_gile
Visual Studio should help you if extend the popup near the electric light bulb.
using System.Text.RegularExpressions;
Gilles Chanteau
GileCAD
GitHub
Message 24 of 46
muckmailer
I have been working with the routine a little and it appears that it is not change Mtext height the
two statements.
else
                        //var mtext = (MText)tr.GetObject(id, OpenMode.ForRead);
                        var mtext = (MText)tr.GetObject(id, OpenMode.ForWrite);
                        mtext.Height = textStyles[mtext.TextStyleName];
Any suggestions?
Thank you,
Message 25 of 46
_gile
Have you watched the formatting of the mtext?
As for the width, the height can be affected by this formatting.
Gilles Chanteau
GileCAD
GitHub
Message 26 of 46
muckmailer
Well I have tried the following:
using (var tr = db.TransactionManager.StartTransaction())
                foreach (SelectedObject so in psr.Value)
                    var id = so.ObjectId;
                    if (id.ObjectClass.IsDerivedFrom(textClass))
                        var text = (DBText)tr.GetObject(id, OpenMode.ForWrite);
                        text.Height = textStyles[text.TextStyleName];
                    else
                        //var mtext = (MText)tr.GetObject(id, OpenMode.ForWrite);
                        var regex = new System.Text.RegularExpressions.Regex(@"\\W\d*(\.\d+)?;", System.Text.RegularExpressions.RegexOptions.IgnoreCase);
                        mtext.Contents = regex.Replace(mtext.Contents, "");
                tr.Commit();
Right now I am getting the error message
Message 27 of 46
ActivistInvestor
Look at the error message.  What do you think eNotOpenForWrite means?
You can't modify an object unless you open it for write.
                    else
                tr.Commit();
Message 28 of 46
muckmailer
Yes I found the "For read" problem.
Could the mtext be exploded to text then formatted to height and width.
In the intellosense I see Mtext.explode but I don't know how to use it
and I don't know where to go to find reference material on it other than google.
Thank you,
Message 29 of 46
_gile
This seems to work from the some tests I did.
        [CommandMethod("THWU")]
        public void TextHeightWidthUpdate()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var textStyleHeights = GetFixedHeightTextStyles(db);
            var textStyleWidths = GetFixedWidthTextStyles(db);
            var filter = new SelectionFilter(new[] { new TypedValue(0, "MTEXT,TEXT") });
            var psr = ed.SelectAll(filter);
            if (psr.Status != PromptStatus.OK)
                return;
            var textClass = RXObject.GetClass(typeof(DBText));
                        if (textStyleHeights.ContainsKey(text.TextStyleName))
                            text.Height = textStyleHeights[text.TextStyleName];
                        if (textStyleWidths.ContainsKey(text.TextStyleName))
                            text.WidthFactor = textStyleWidths[text.TextStyleName];
                    else
                        // set the text height equal to the textstyle height (if different from 0)
                        if (textStyleHeights.ContainsKey(mtext.TextStyleName))
                            mtext.TextHeight = textStyleHeights[mtext.TextStyleName];
                        // remove width and height formatting
                        double widthFactor = textStyleWidths.ContainsKey(mtext.TextStyleName) ?
                            textStyleWidths[mtext.TextStyleName] :
                            1.0;
                        TextEditor textEditor = TextEditor.CreateTextEditor(mtext);
                        textEditor.SelectAll();
                        textEditor.Selection.WidthScale = widthFactor;
                        textEditor.Selection.Height = textEditor.TextHeight;
                        textEditor.Close(TextEditor.ExitStatus.ExitSave);
                tr.Commit();
        Dictionary<string, double> GetFixedHeightTextStyles(Database db)
            using (var tr = db.TransactionManager.StartOpenCloseTransaction())
                return ((TextStyleTable)tr.GetObject(db.TextStyleTableId, OpenMode.ForRead))
                    .Cast<ObjectId>()
                    .Select(id => (TextStyleTableRecord)tr.GetObject(id, OpenMode.ForRead))
                    .Where(ts => ts.TextSize > 0.0)
                    .ToDictionary(ts => ts.Name, ts => ts.TextSize);
        Dictionary<string, double> GetFixedWidthTextStyles(Database db)
                    .Cast<ObjectId>()
                    .Where(ts => ts.XScale > 1.0)
                    .ToDictionary(ts => ts.Name, ts => ts.XScale);
Gilles Chanteau
GileCAD
GitHub
Message 30 of 46
muckmailer
 Give me a little time to work with this routine.
 Since I am a beginner and not my primary job it will take some time.
 I plan on keeping the thread open for that reason.
I looked at of your tutorial webpages.
Do you have any of your tutorials that are in English?
Thank you,
Message 31 of 46
_gile
Only this one which was mainly translated with Bing and/or Google I don't remember.
Gilles Chanteau
GileCAD
GitHub
Message 32 of 46
muckmailer
The routine works but how do I learn how to create such a routine?
How do I know how to use the keywords to use in intellisense show to properly
make a usable statement in c sharp and AutoCAD? Do you use the AutoDesk Developer
wepage to do that?
I am also looking for a good C sharp AutoCAD tutorial because I don't know what some
terms mean. For example I think you used "casting".
There should be some good material out there somewhere for the beginner but I
can't find it.
Thank you,
Message 33 of 46
_gile
You should learn C# / .NET / Visual Studio / OOP outside of AutoCAD first. There's a big amount of learning material for this.
And only after you're cumfortable with all this stuff, you can come back to AutoCAD programming with some background which will compensate the lack of documentation of the AutoCAD API.
Gilles Chanteau
GileCAD
GitHub
Message 34 of 46
ActivistInvestor
wepage to do that?
can't find it.
Thank you,
In that case, I would suggest first learning how to use the Internet as a resource.
For example, learning how to use google to search for learning material for programming.
Message 35 of 46
muckmailer
Would looking at VS class view give me some ideal how the AutoCAD.net paths are organized?
Could this be done in VS object browser?
Do need to look at Autodesk webpages to get an ideal of AutoCAD structure that
determines how these path are composed?
Message 36 of 46
ActivistInvestor
I'm not sure what you mean by 'paths'.
The API is very large and contains many classes. The only way to become familiar with it is to read the docs, and study the code samples, or enroll in some sort of training class.
Message 37 of 46
_gile
If you have (and you should have) download and install some ObjectARX SDK, you can find in the class map folder, a classmap.dwg file showing the class hierarchy.
Gilles Chanteau
GileCAD
GitHub
Message 38 of 46
muckmailer
Well I just down loaded and installed. Looks like there is a docs folder with a setup files. I installed those files but I don't know where to go to use  the documents files.  Is there some useful tools in that folder?
Message 39 of 46
ActivistInvestor
Double-click on arxmgd.chm
Message 40 of 46
muckmailer
If I start the update routine using a form button with the attached code the
routine does not do anything until after:
1. The button is pushed
2. I exit the form the button is in.
3. I hit the return key on the keyboard
How can I put this routine in a loop?
For example a file loop to that open and closes
several drawings for update?
Thank you,
private void button7_Click(object sender, EventArgs e)
           //Routine TextHeightUpdateNoElock() [CommandMethod("THWU")]
            var doc = Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.MdiActiveDocument;
            if (doc != null)
                doc.SendStringToExecute("THWU", false, false, false);
