Text Height Update In C Sharp
muckmailer
Message 1 of 46
muckmailer
The following Lisp route will update text by style. Can this be done in C sharp?
I am looking for a c sharp routine that would have an select all so I can make changes to all text in the drawing.
;;  TextHeightUpdate.lsp [command name: THU]
;;  To Update the Height of Text and Mtext in Styles with defined heights,
;;    when height has been changed in Style definition.  Checks Style of all
;;    selected Text/Mtext, and it has a defined height, imposes that on object.
(defun C:THU (/ ss n obj ht)
  (prompt "\nTo Update the Height of fixed-height Text/Mtext,")
  (if (setq ss (ssget '((0 . "TEXT,MTEXT"))))
    (repeat (setq n (sslength ss))
      (setq obj (vlax-ename->vla-object (ssname ss (setq n (1- n)))))
      (if
        (> (setq ht (cdr (assoc 40 (tblsearch "style" (vla-get-StyleName obj))))) 0)
        (vla-put-Height obj ht); then
      ); if
    ); repeat
  ); if
  (princ)
); defun
(vl-load-com)
(prompt "\nType THU for Text Height Update.")
Thank you
Replies (45)
Message 2 of 46
_gile
When you say "select all", do you mean:
  • in the current space
  • in all spaces
  • in all spaces and block definition
Gilles Chanteau
GileCAD
GitHub
Message 3 of 46
_gile
This mimics the LISP except it does a (ssget "_X" ...)
        [CommandMethod("THU")]
        public void TextHeightUpdate()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var filter = new SelectionFilter(new[] { new TypedValue(0, "MTEXT,TEXT") });
            var psr = ed.SelectAll(filter);
            if (psr.Status != PromptStatus.OK)
                return;
            using (var tr = db.TransactionManager.StartTransaction())
                foreach (SelectedObject so in psr.Value)
                    var id = so.ObjectId;
                    if (id.ObjectClass.DxfName == "TEXT")
                        var text = (DBText)tr.GetObject(id, OpenMode.ForRead);
                        var textStyle = (TextStyleTableRecord)tr.GetObject(text.TextStyleId, OpenMode.ForRead);
                        if (textStyle.TextSize > 0)
                            tr.GetObject(id, OpenMode.ForWrite);
                            text.Height = textStyle.TextSize;
                    else
                        var mtext = (MText)tr.GetObject(id, OpenMode.ForRead);
                        var textStyle = (TextStyleTableRecord)tr.GetObject(mtext.TextStyleId, OpenMode.ForRead);
                            mtext.Height = textStyle.TextSize;
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
Message 4 of 46
_gile
Here's an optimization of the previous routine which first collect all the names and heights of textsyles which TextSize is greater than 0.
            var textStyles = GetFixedHeightTextStyles(db);
            if (!textStyles.Any())
                return;
                new TypedValue(0, "MTEXT,TEXT"),
                new TypedValue(7, string.Join(",", textStyles.Keys))
                return;
            var textClass = RXObject.GetClass(typeof(DBText));
                    if (id.ObjectClass.IsDerivedFrom(textClass))
                        var text = (DBText)tr.GetObject(id, OpenMode.ForWrite);
                        text.Height = textStyles[text.TextStyleName];
                    else
                        mtext.Height = textStyles[mtext.TextStyleName];
                tr.Commit();
        Dictionary<string, double> GetFixedHeightTextStyles(Database db)
            using (var tr = db.TransactionManager.StartOpenCloseTransaction())
                return ((TextStyleTable)tr.GetObject(db.TextStyleTableId, OpenMode.ForRead))
                    .Cast<ObjectId>()
                    .Select(id => (TextStyleTableRecord)tr.GetObject(id, OpenMode.ForRead))
                    .Where(ts => ts.TextSize > 0.0)
                    .ToDictionary(ts => ts.Name, ts => ts.TextSize);
Gilles Chanteau
GileCAD
GitHub
Message 5 of 46
muckmailer
I would like to select all Text, Mtext and I think dtext if in the drawing if that is possable.
If I could controll include attributes and text in blocks that would be great but I think that would make things too complex.
I plan on putting the routine in a batch loop.  I am hoping to eventually control text height, width and maybe style. Especially Height & width.
I have modified that ssget in that lisp routine to select all text but I would have to load it and use command send to use it in VS.
Thank
Message 6 of 46
_gile
The above codes select all Texts and Mtexts in the drawing, like: (ssget "_X" '((0 . "TEXT.MTEXT")))
Gilles Chanteau
GileCAD
GitHub
Message 7 of 46
muckmailer
On the last routine I got the following error.
Message 8 of 46
GiaBach
Please change this line :
to :
var mtext = (MText)tr.GetObject(id, OpenMode.ForWrite);
Message 9 of 46
muckmailer
That made it have an e-lock violation.
Message 10 of 46
_gile
to :
@GiaBach thanks for correcting this.
Gilles Chanteau
GileCAD
GitHub
Message 11 of 46
_gile
Please describe how do you use the command, this error won't occur when calling the THU command from command line.
Gilles Chanteau
GileCAD
GitHub
Message 12 of 46
muckmailer
I make a form and use allow me to a button.
Here is the code I have now I think it works. I put lockdoc code in it.
  private void button11_Click(object sender, EventArgs e)
            //ObjMycommands.RemoveTxtOverrides();
            //Test();
            // ChangeTextsize();
            //SendACommandToAutoCAD();
            TextHeightUpdate();
       //Update Routine
            System.Windows.Forms.MessageBox.Show("THU");
            var doc = Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.MdiActiveDocument;
                return;
                return;
            using (DocumentLock docLock = doc.LockDocument())
                        else
                            //var mtext = (MText)tr.GetObject(id, OpenMode.ForRead);
                    tr.Commit();
                }//using
            }//Routine
                    .Cast<ObjectId>()
//Update Routine
Message 13 of 46
_gile
The request in the OP was to mimic a LISP command, so I replied with a .NET command.
I could not guess that you wanted an event handler for a button.
Anyway, Im glad you get it work.
You could avoid using the LockDocument by calling the command from the button event handler (safer way):
if (doc != null)
doc.SendStringToExecute("THU ", false, false, false);
Gilles Chanteau
GileCAD
GitHub
Message 14 of 46
muckmailer
What does false do in  "THU ", false, false, false.
I never did find any information true/false keywords on that in the Autodesk webpages.
Thank you,
Message 15 of 46
_gile
Have a look >>here <<.
Gilles Chanteau
GileCAD
GitHub
Message 16 of 46
muckmailer
So if I put your routine in Mycommands and start it with a type-in command I do not have the e-lock problem.
If place that same routine in a form module that introduces the e-lock violation.
If it try something like the code I have in button 12 I still have the e-lock violation.
So is placing AutoCAD routines in Mycommands and using command send to avoid e-lock violations
is the preferred menhod if you wnat to use form controls?
I the past I thought they recommand not using command sends. Why is it prefered over
using LockDocument? Why is that safer?
//Start Update Routine
            if (doc != null)
        private void button12_Click(object sender, EventArgs e)
            // This gives elock Violation,
            MyCommands ObjTHUStart = new MyCommands();
            ObjTHUStart.TextHeightUpdate();
Message 17 of 46
_gile
Extract from Kean Walmsley blog:
Once again there’s our important rule of thumb when it comes to implementing a modeless UI: rather than manually locking the current document, it’s safer to define a command – which will implicitly lock the current document – and call that from the UI via SendStringToExecute().
I'ts safer because you let AutoCAD take care of locking the document (and setting the focus to the AutoCAD window).
Another advantage is that it also allows the user to hit Enter to re-launch the command.
Gilles Chanteau
GileCAD
GitHub
Message 18 of 46
muckmailer
I would like to expand this routine to also update mtext & text widths
so I add the following lines to your code.
text.WidthFactor = textStyles[text.TextStyleName];
// mtext.How do I know what intellisense keywords do?
else
//mtext.??? = textStyles[text.TextStyleName];
So I thinik I might have guessed the text.WidthFactor to for text width but I am puzzled on how the control M text width by looking at
intellsense keywords. So how can I control Mtext width in this routine and how know learn how to use effectivly use
intellisense keywords? How do I learn the intellsense roadmap for AutoCAD? Is there a good guide or tutorial for these words?
Message 19 of 46
_gile
With MText instances, the width factor in MTEXT formatting (\W) which can affect only a portion of the text.
See >>here<< and >>there<<.
You can easily remove all mtext formatting doing:
mtext.TextString = mtext.Text;
but only removing some formatting is not so trivial.
Gilles Chanteau
GileCAD
GitHub
Message 20 of 46
_gile
You can try using regular expression:
var regex = new Regex(@"\\W\d*(\.\d+)?;", RegexOptions.IgnoreCase);
mtext.Contents = regex.Replace(mtext.Contents, "");
Gilles Chanteau
GileCAD
GitHub
