Table Flow Direction
I tried to use the command: tablestyle.FlowDirection = FlowDirection.BottomToTop when defining the table style but that did not work.
Then I used table.FlowDirection = FlowDirection.BottomToTop when defining the table but that did not work also.
Any other ideas?
1.  Committing your transaction?
2.  In the old day, tables were ripped out of the NOD and then loaded into a table class object by the ID with a trans.getobject, perhaps you don't have a proper instance of the table.
I just found out I have to use an integer instead.  tablestyle.flowdirection = 0 (for down) or 1 (for up).
deltacadd
You should also cast the integer to FlowDirection, as in:
tablestyle.FlowDirection = (FlowDirection) 1; // For BottomToTop
or
table.FlowDirection = (FlowDirection) 1;
Hope this helps someone.
rui143
You can set the tablestyle like
TableStyle ts = new TableStyle();
ts.FlowDirection = (FlowDirection)1;    //Buttom to Up
