System.Windows.Media.Animation
has anyone seen this before. It comes up in the "immidiate wndow", when I test my command in Cad:
System.Windows.Media.Animation Warning: 6 : Unable to perform action because the specified Storyboard was never applied to this object for interactive control.; Action='Stop'; Storyboard='System.Windows.Media.Animation.Storyboard'; Storyboard.HashCode='62744049'; Storyboard.Type='System.Windows.Media.Animation.Storyboard'; TargetElement='Autodesk.Windows.ToolTip: Quick Select'; TargetElement.HashCode='60015878'; TargetElement.Type='Autodesk.Windows.ToolTip'
Cheers,
Martin.
Check the thread started by HEnnulat Oct. 8, 2009. Does that look the same?
No answer, but you are not alone.
Hi, fieldguy
the only one I could find is this one: [http://discussion.autodesk.com/forums/thread.jspa?messageID=6267438ꈮ|here]
And that's started on the 7th?
Cheers,
Martin.
Is the CopyLocal property of your assembley references set to false?
And, is 'Enable Just My Code' checked in your debug settings?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2011
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:[email protected]...
Hi, fieldguy
Cheers,
Martin.
For me, yes. I am not using the references from the sdk. I have a command
button in a container on an autocad palletteset (User Control), and
Or CommandFlags.Modal))> _
It works fine except for the messages as described in the HEnnulat post. I
have seen the storyboard messages as in quigs post as well but I am not
getting them anymore.
Win 7 Pro 64 bit
VS2008
Autocad Map 3D 2010
