Synchronous SENDCOMMAND
I am trying to write a very simple command processor and in fact the bulk of the code is also used in another .NET program which does function fine and is capable of executing a command (another .NET program) on groups of drawings synchronously without a problem (everything marked as ORIGINAL CODE).
Moreover I have been chasing my tail trying a number of configurations and I keep coming back to the same point which is if I have CommandFlags.Session specified in my CommandMethod statement then the application is running in application mode which is necessary so that the SendCommand function will operate synchronously (which it does in my other program).
What happens with the code as shown below is the program runs and dutifully brings up each drawing, saves it and closes the file and then when I exit my form it creates three circles in the initial file (Drawing1.DWG) and zooms extents (asynchronous sendcommand).
If I disable the CloseAndSave function and instead use Saveas and then CloseandDiscard (which is what my other program uses without problem) the program hangs up AutoCAD after bringing up the initial drawing.
This is from the ADNDEV Blog:
If your code is executed in document context, you do not have to lock the document. Therefore, when you execute a command that has been registered via acedDefun(),or when it has been registered via acedRegCmds->addCommand() WITHOUT the ACRX_CMD_SESSION flag (CommandFlags.Session in .NET), YOUR CODE EXECUTES IN DOCUMENT CONTEXT. In this context, AutoCAD LOCKS THE CURRENT DOCUMENT FOR YOU and unlocks it when your function ends. If you have to access other documents in the document context, you have to lock the other documents 'manually'. YOU SHOULD register your command for the application context by using the ACRX_CMD_SESSION command flag (CommandFlags.Session in .NET).
My understanding here is if I am using CommandFlags.Session then I am executing in application context (which I was also given to understand is also necessary for SendCommand to execute synchronously) which interestingly is not what IsApplicationContext is indicating.
Any help is appreciated (code follows - a cleaner version is attached in PDF).
<Autodesk.AutoCAD.Runtime.CommandMethod("ProcessBtn_Click", CommandFlags.Session)> _
    Public Sub ProcessBtn_Click()
    CMDSTR = processCMD()        ' Like: CIRCLE 10,10 6 ZOOM E
    Try
        For Each dwg As String In DWGLIST
                '   Dim acDocMgr As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
                '   Dim doc = DocumentCollectionExtension.Open(acDocMgr, dwg, False)
                Dim doc = OpenDWG(dwg, False)        ' ORIGINAL CODE
                If doc IsNot Nothing Then
                    Dim indx As Integer
                    FilesList.SelectedIndex = indx : indx = indx + 1
                    Label1.Content = "Pacificorp Batch Command Processor WORKING: OPENING --> " & dwg & " [" & _
                                 indx.ToString & "] Of [ " & DWGLIST.Count.ToString & "]... AppContext is: " & _
                                 Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.IsApplicationContext.ToString
                    Using doclok As Autodesk.AutoCAD.ApplicationServices.DocumentLock = doc.LockDocument
                        If doc.IsReadOnly = False Then
                            Try
                                Dim acapp As AcadApplication = _
                                Marshal.GetActiveObject("AutoCAD.Application.19.1")        '   ORIGINAL CODE
                                acapp.ActiveDocument.SendCommand(CMDSTR)        '   ORIGINAL CODE
                                '   doc.Database.SaveAs(dwg, True, doc.Database.OriginalFileVersion, doc.Database.SecurityParameters)      '   ORIGINAL CODE
                                '   DocumentExtension.CloseAndDiscard(doc)        '   ORIGINAL CODE
                                DocumentExtension.CloseAndSave(doc, dwg)  '   Seems to operate in the current thread only
                            Catch ex As Autodesk.AutoCAD.Runtime.Exception
                            If doc.IsActive Then DocumentExtension.CloseAndDiscard(doc)
                                MsgBox("Error (Inner): " & ex.Message, MsgBoxStyle.OkOnly, "Batch Processor Error")
                            Finally
                            doc.Dispose()
                            End Try
                        Else
                            Label1.Content = "Batch Command Processor: Doc. Is ReadOnly --> " & dwg
                        End If
                    End Using
           End If
            Next
            MsgBox("Error (Outer): " & ex.Message, MsgBoxStyle.OkOnly, "Batch Processor Error")
        End Try
End Sub
Public Function SelectDoc(ByVal filename As String, _
     Optional ByVal ForWrite As Boolean = False) As Document
   Dim docs As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
  Try
      For Each doc As Document In docs
          If doc.Name.ToUpper = fullname.ToUpper Then
              If doc.Name = Autodesk.AutoCAD.ApplicationServices.
                           Application.DocumentManager.MdiActiveDocument.Name Then
                If doc.IsReadOnly = Not ForWrite Or doc.IsReadOnly = False Then
                     Return doc
                 Else
                    Return Nothing
                 End If
             Else
                 If doc.IsReadOnly <> ForWrite Or ForWrite = False Then
                     Application.DocumentManager.MdiActiveDocument = doc
                     Return doc
                Else
                     Return Nothing
                 End If
              End If
         End If
       Next
Catch ex As SystemException
         MsgBox("Error in OpenDWG [" & ex.Message & "] ", MsgBoxStyle.OkOnly,  "Command Process")
   End Try
   Return Nothing
End Function
Public Function OpenDWG(ByVal fullname As String, ByVal ForReadOnly As Boolean) As Document
   Try
       Dim docs As DocumentCollection = _
       Try
          Dim doc As Document = SelectDoc(fullname, Not ForReadOnly)
              Return doc
         Else
              doc = DocumentCollectionExtension.Open(docCol:=docs, fileName:=fullname, _
                                                     forReadOnly:=False)
              If ForReadOnly = False And doc.IsReadOnly = True Then
                 doc.DowngradeDocOpen(True)
                  Return Nothing
             Else
                 Return doc
             End If
          End If
           Return Nothing
       End Try
       MsgBox("Error in OpenDWG [" & ex.Message & "] ", MsgBoxStyle.OkOnly,  "Command Process")             Return Nothing
   End Try
End Function
hgasty1001
You may find interesting this post from Gilles Chanteau in The Swamp: Editor.Command vs Editor.CommandAsync
Gaston Nunez
Gaston --
Yes very interesting indeed and good to know I will be trying Editor.command in place of Sendcommand for sure.
However I discovered the problem I was experiencing had nothing to do with the Sendcommand function or application context for that matter I was using a modal form when I should have been using a modeless one, when I made the change everything began to work again.
I was pointed in that direction from another post in the forum: Please verify: DocumentCollection.Open(dwgfileName) does not work when a modal dialog box is loaded.
Thank you very much.
Jim --
