SymbolUtilityServices Version Change?
When I need to find the space I was in for 2006 in wrote this
SymbolUtilityServices service = new SymbolUtilityServices();
currentSpaceId = service.GetBlockModelSpaceId(HostApplicationServices.WorkingDatabase)
This worked just fine
Now when I try this using the acdbmgd and acmgd references from AutoCAD 2008 the project compiles but when I run the app I get this error:
--> System.MissingMethodException: Method not found: 'Autodesk.AutoCAD.DatabaseServices.ObjectId Autodesk.AutoCAD.DatabaseServices.SymbolUtilityServices.GetBlockModelSpaceId(Autodesk.AutoCAD.DatabaseServices.Database)'.
To make it work I have to now use:
currentSpaceId = SymbolUtilityServices.GetBlockModelSpaceId(HostApplicationServices.WorkingDatabase)
am I doing something wrong? Or has something changed
Your code was wrong to start with. You
shoudn't create instances of that class.
The method you're calling is static.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2008
Supporting AutoCAD 2000 through 2008
http://www.acadxtabs.com
wrote in message news:5570207@discussion.autodesk.com...
Yes, I see that now but if I try
currentSpaceId = SymbolUtilityServices.GetBlockModelSpaceId(HostApplicationServices.WorkingDatabase);
using references to autocad 2006 the compiler gives me this error:
An object reference is required for the nonstatic field, method, or property 'Autodesk.AutoCAD.DatabaseServices.SymbolUtilityServices.GetBlockModelSpaceId(Autodesk.AutoCAD.DatabaseServices.Database)' (CS0120)
For anyone interested, changes have been made.
By Reflecting both 2006 and 2008 acdbmgd.dll and looking at
GetBlockModelSpaceId we find these differences:
2007: public static unsafe ObjectId GetBlockModelSpaceId(Database databasePointer)
2006: public unsafe ObjectId GetBlockModelSpaceId(Database databasePointer)
So it has been changed to a static method in 2008.
I guess my code wasn't wrong for the 2006 version.
