Switch Drawings?
Switch Drawings?
mark
Message 1 of 9
Switch Drawings?
mark
Hi everyone, I'm looking for some help switching the currently active drawing file.
I have 2 drawings for my example. Drawing A and Drawing B.
I have Drawing A currently open, i run my program and it opens the Drawing B, however once Drawing B is completely open, AutoCAD is switching back to Drawing A.
So I'm wondering if anyone knows how to force AutoCAD to switch back to Drawing B? Basically just like how you go to the window pulldown then pick another drawing and AutoCAD switches drawings.
Thanks for any help!!
Mark
Replies (8)
Message 2 of 9
Can you post a code snippet that shows how you open the file?
If you're doing this from a registered command, the CommandFlags parameter
should include CommandFlags.Session, and you need to documents before you
modify anything in them.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
wrote in message
news:6174144@discussion.autodesk.com...
drawing file. I have 2 drawings for my example. Drawing A and Drawing B. I
Drawing A. So I'm wondering if anyone knows how to force AutoCAD to switch
then pick another drawing and AutoCAD switches drawings. Thanks for any
help!! Mark
Message 3 of 9
mark
Like this (I'm open to suggestions to change of course)
X.Path is the path to the drawing file of course.
Dim MyApp As AcadApplication
MyApp = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication
MyApp.Application.Documents.Open(X.Path)
After this part, AutoCAD swaps back to the original Drawing A?
Thanks Tony for taking a look.
Mark
Message 4 of 9
This works for me.
Dim NewDoc As Document = Application.DocumentManager.Open(DwgNam, False)
If SetAct = True Then
Application.DocumentManager.MdiActiveDocument = NewDoc
End If
Warning, its highly likely that vile criticism will follow this post.
Terry
Message 5 of 9
Mark - The problem isn't the code you posted, but the context you're calling
it from.
As I mentioned before, are you calling this from a command that's registered
with the [CommandMethod] attribute? If not, where are you calling it from?
wrote in message
news:6174227@discussion.autodesk.com...
Like this (I'm open to suggestions to change of course) X.Path is the path
to the drawing file of course. Dim MyApp As AcadApplication MyApp =
MyApp.Application.Documents.Open(X.Path) After this part, AutoCAD swaps back
to the original Drawing A? Thanks Tony for taking a look. Mark
Message 6 of 9
The criticism is warranted given that your post demonstrates that you don't
have the slightest clue that the code you posted is actually just another
way of calling the code that Mark shows in his post (the Open() method of
the DocumentCollection calls the Open() method of the AcadDocuments
COM object - the same method that Mark is calling).
Duh!
"Terry W. Dotson" wrote in message
news:6174536@discussion.autodesk.com...
This works for me.
End If
Terry
Message 7 of 9
Hi. You're the owner of this forum, Tony? I've seen a Tony reply on about every thread I've read here. 🙂
So, by using the CommandFlags.Session parameter in the attribute, the code are executed in the acad session context, not in the drawing?
[CommandMethod("SWITCH"), CommandFlags.Session]
public static void SwitchWindow()
Application.DocumentManager.Open("c:\\D1.dwg", false);
This worked neatly.
Curious about:
"and you need to documents before you modify anything in them."
I have to do what with the documents?
Message 8 of 9
"and you need to lock documents before you modify anything in them".
It was probably a phone call in the middle of typing the sentence.
wrote in message news:6175809@discussion.autodesk.com...
every thread I've read here. 🙂 So, by using the CommandFlags.Session
context, not in the drawing? [CommandMethod("SWITCH"), CommandFlags.Session]
public static void SwitchWindow() {
Application.DocumentManager.Open("c:\\D1.dwg", false); } This worked neatly.
Curious about: "and you need to documents before you modify anything in
them." I have to do what with the documents?
Message 9 of 9
Hello, I'm having a similar problem but when I try to include the CommandFlags.Session parameter like so:
[CommandMethod("JOpen"), CommandFlags.Session]
I get an error:
The type name 'SessionAttribute' does not exist in the type 'Autodesk.AutoCAD.Runtime.CommandFlags'
Any help would be appreciated, Thanks.
