Support Folder Add
Support Folder Add
k005
Advisor Advisor
Message 1 of 19
Support Folder Add
k005
Hi All !
My aim is to make an addition to AutoCAD support folders. But I want to do this with command.
sample :
 E:\BlockRAM
How can I do that ?
Replies (18)
Message 2 of 19
R.Gerritsen4967
Look around in this topic. Especially this post. I'm sure you will find what you need...
Message 3 of 19
k005
I took a look at the codes here, I think it might be.
I'll try... Thank you.
* I'm sure too.. 🙂
Message 4 of 19
Ed__Jobe
Here is my solution.
        Private Sub AppendSupportPath(ByVal FilePath As String)
            Try
                Dim app As AcadApplication = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication
                Dim files As AcadPreferencesFiles = app.Preferences.Files
                Dim ary As String() = files.SupportPath.Split(";")
                Dim bln As Boolean = False
                '  Check to see if its already added.
                For Each Str As String In ary
                    If Str = FilePath Then bln = True
                Next
                '   If not, add it.
                If bln = False Then
                    files.SupportPath = files.SupportPath.ToString & ";" & FilePath.ToString
            Catch ex As Autodesk.AutoCAD.Runtime.Exception
            End Try
        End Sub
        Private Sub PrependSupportPath(ByVal FilePath As String)
            Try
                Next
                '   If not, add it.
                If bln = False Then
                    files.SupportPath = FilePath.ToString & ";" & files.SupportPath.ToString
            End Try
        End Sub
Ed
How to post your code.
Message 5 of 19
k005
Thanks for the code.
But where do I add the E:\blocksRAM path here?
i didn't see it. and i have to do it with C# codes.
Message 6 of 19
Ed__Jobe
It's a sub. You supply the path string in the argument.
'some other sub
   AppendSupportPath("E:\blocksRAM")
'continue work
Note that these functions are in VB. You may need to convert them to C#. They are from my first dll which I haven't converted to C#. They also handle inserting a ; between paths. Just supply the path you want. If you want to add multiple paths, just call the sub multiple times.
Ed
Message 7 of 19
k005
I understand now. Thank you.
* I wanted to add this to my DVB file, got some errors.
Message 8 of 19
norman.yuan
Well, your code is VBA code, not .NET/VB.NET. So, you might as well ask the question in VBA forum in future.
Anyway, VBA (and old classical VB) does not support "Try....Catch...", nor Array in VBA supports "For Each...Next". (Hint: you cannot copy VB.NET code into AutoCAD's VBA and expect it to work).
Norman Yuan
Drive CAD With Code
Message 9 of 19
k005
Yes I know.
But I don't know VBA exactly... There were small programs I prepared before. I thought it might work because the codes are similar...
Even though it works, I need C# codes, Sir.
Thank you.
Message 10 of 19
k005
Yes I know.
Thank you.
Message 11 of 19
Ed__Jobe
Here it is in C#.
using System;
using System.Windows.Forms;
using Autodesk;
using Autodesk.AutoCAD.ApplicationServices;
using acApp = Autodesk.AutoCAD.ApplicationServices.Application;
using Autodesk.AutoCAD.Interop;
namespace TID_
    public class Helper
        private void AppendSupportPath(string FilePath)
            try
                AcadApplication app = acApp.AcadApplication;
                AcadPreferencesFiles files = app.Preferences.Files;
                string[] ary = files.SupportPath.Split(';');
                bool bln = false;
                //  Check to see if its already added.
                foreach (String Str in ary)
                    if (Str == FilePath)
                        bln = true;
                //   If not, add it.
                if (bln == false)
                    files.SupportPath = files.SupportPath + ";" + FilePath;
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                MessageBox.Show("Error Occured in AppendSupportPath. " + ex.Message + ", ", "AppendSupportPath Error", MessageBoxButtons.OK, MessageBoxIcon.Error);
        private void PrependSupportPath(string FilePath)
            try
                bool bln = false;
                        bln = true;
                //   If not, add it.
                if (bln == false)
                    files.SupportPath = files.SupportPath = FilePath + ";" + files.SupportPath;
                MessageBox.Show("Error Occured in PrependSupportPath. " + ex.Message + ", ", "PrependSupportPath Error", MessageBoxButtons.OK, MessageBoxIcon.Error);
Ed
Message 12 of 19
k005
 I'm getting errors in these parts., I'm trying to fix it...
AcadApplication app = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
Message 13 of 19
Ed__Jobe
Did you add a reference to Autodesk.AutoCAD.Interop? Any time you have a 'using' statement, you have to first reference the appropriate library. It's like trying to order a burger at Subway. They have to have it before you can use it.
Ed
Message 14 of 19
k005
Yes I know. i added that too. But there are still errors.
Message 15 of 19
Ed__Jobe
Did you include the using statement I had? Do you have the standard references to  the autocad dll's? ...and their corresponding using statements?
I also noticed some typos. Stand by.
Ed
Message 16 of 19
k005
Yes there is.
But it needs to be simplified a little more.
* So how can we do this more simply?
for example ;
Aapp.Application.SetSystemVariable("Lispsys", 0); etc..
our process is just to introduce a folder.
This shouldn't require a lot of code. Because the process is too short...
Message 17 of 19
Ed__Jobe
I revised the code the previous post.
Ed
Message 18 of 19
Ed__Jobe
@k005 wrote:
Yes there is.
for example ;
There is only one way to set the search file paths. It is stored as a semi-colon delimited string in the application Preferences object, which is only accessible by COM.
Ed
Message 19 of 19
k005
Yes it is OK. Thank you very much., 🤗
