Support FIles 2008
Support FIles 2008
Support FIles 2008
Maybe I am blind, but I can't seem to find
the Support FIles in the Preferenece.Files
It used to be there in 2006!
Has it moved, or is there another way to get the support file string in 2008.
Thanks in advance.
I presume you are talking about the ActiveX API. In which case I am still using it in VBA with 2008.
Regards - Nathan
This is what I am trying to do:
Autodesk.AutoCAD.Interop.AcadApplication oApp = (Autodesk.AutoCAD.Interop.AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
AcadPreferencesFiles files = oApp.Preferences.Files
string supportFiles = files. <--- SupportPath is not a option!!!!
What am I doing wrong?
It shows up for me with VB.NET.
Dim acadApp As Autodesk.AutoCAD.Interop.AcadApplication = Application.AcadApplication
Dim files As Autodesk.AutoCAD.Interop.AcadPreferencesFiles = acadApp.Preferences.Files
Dim strSPath As String = files.SupportPath
I must be doing something wrong.
I get everything but supportpath.
All I need to do is add to my references "Autodesk.AutoCAD.Interop"
is that not correct? (of course besides "acdbmgd" and "acmgd")
It strange because in the class explorer I cannot find SupportPath anywhere!
The only thing I can suggest is that I am using MAP where it may have been fixed so maybe someone else can check. I haven't actually tried the code but I can see it in the object browser and it does come up with intellisense.
Regards - Nathan
I have referenced from AutoCAD MAP 2007 the following
acdbmgd
acmgd
Now in the Class Browser this is what I see
(see attached image)
I have now tried this on 2 diffrent computers. I obviously dont understand what I am doing wrong.
Thanks for your help.
