stuck in Ribbonbutton.CommandHander , i have created wpf UI
Aravinth.Pichamani
Message 1 of 11
Aravinth.Pichamani
using Autodesk.AutoCAD.ApplicationServices;
using System;
using System.Windows.Controls.Ribbon;
using System.Windows.Input;
using acadApp = Autodesk.AutoCAD.ApplicationServices.Application;
namespace LabelsCross
    public class RibbonCommandHandler : ICommand
        public event EventHandler CanExecuteChanged;
        public bool CanExecute(object parameter)
            return true;
        public void Execute(object parameter)
            Document doc = acadApp.DocumentManager.MdiActiveDocument;
            if (parameter is RibbonButton)
            {// here what i neeed do
                Application.ShowModelessWindow(?);
Replies (10)
Message 2 of 11
Aravinth.Pichamani
this my WPF code
Message 3 of 11
ActivistInvestor
Are you familiar with how to create a Window like the one you show?
You need to create an instance of the Window and pass it as the argument to ShowModalWindow().
Message 4 of 11
Aravinth.Pichamani
I'm familiar with WPF. I'm created above show picture. But when I'm clicking button not showing windows (wpf)
Message 5 of 11
ActivistInvestor
You are not showing the relevant code.
In the code you showed you have a question mark as the argument. What are you passing as that argument?
Message 6 of 11
norman.yuan
Which button you click? Since you showed the code of RibbonCommandHandler, I assume the RibbonCommandHandler is SUPPOSED to be assigned to a RibbonCommandItem (typically a RibbonButton) created by your code. So, does your code creates a such RibbonCommandItem? If yes, show the code. If not, I do not see the code of RibbonCommandHandler is relevent when it is not used anywhere. It might be too much for someone who is not yet very familiar to AutoCAD .NET API programming to figure out how to create a RibbonCommandItem in order to just show an UI in AutoCAD. You should begin with creating a simply CommandMethod to show either "Hello AutoCAD" at command line, or show a UI:
[CommandMethod("ShowMyUI")]
public static void ShowMyMainWindow()
   var win=new MainWindow()
   win.DataContext=MyMainViewModel;  // If you do know WPF well, you should do MVVM
   var result = Application.ShowModalWindow(win);
   if (result.HasValue && result.Value)
      // If the modal UI is oked by user
      // you might want to do something based on the user inputs in the UI
With this command "ShowMyUI" available, and you indeed created a RibbonCommandItem, which is assigned the RibbonCommandHandler, then you can set the RibbonCommandItem's CommandParameter property with this command, like
MyRibbonButton.CommandHandler = RibbonCommandHandler;
MyRibbonButton.CommandParameter = "ShowMyUI ";
Then in the RibbonCommandHandler, you can:
                var commandString=((RibbonButton)parameter).CommandParameter.ToString();
                var dwg=Application.DocumentManager.MdiActiveDocument;
                if (dwg != null)
                   dwg.SendStringToExecute(commandString, true, false, false);
Norman Yuan
Drive CAD With Code
Message 7 of 11
Aravinth.Pichamani
    public class EApplication : IExtensionApplication
        public static class Images
            public static BitmapImage GetBitmap(string path)
                BitmapImage bmp = new BitmapImage();
                bmp.BeginInit();
                bmp.UriSource = new Uri(path);
                bmp.EndInit();
                return bmp;
        public static void CreateRibbonbtn()
            RibbonControl ribbon = ComponentManager.Ribbon;
            RibbonTab tab = new RibbonTab();
            // setting the name for the tab
            tab.Title = " LD & ME";
            // settting the id for the tab
            tab.Id = "LD";
            ribbon.Tabs.Add(tab);
            // creating a new panelsource for the tab
            RibbonPanelSource panelSource = new RibbonPanelSource();
            panelSource.Title = "Label";
            // creating a panel from the source
            RibbonPanel panell = new RibbonPanel();
            panell.Source = panelSource;
            // adding the panel to the tabs we created
            tab.Panels.Add(panell);
            //creating a button for the panel we have created
            try
                RibbonButton btn = new RibbonButton();
                btn.Text = "Lable";
                btn.ShowText = false;
                btn.CommandParameter = "";
                btn.ShowImage = true;
                btn.Image = Images.GetBitmap(@"C:\WSP\code\civil 3d c#\LabelsCross\LabelsCross\Resources\pipe.png");
                btn.Orientation = System.Windows.Controls.Orientation.Vertical;
                btn.CommandHandler = new RibbonCommandHandler();
                panelSource.Items.Add(btn);
                btn.Size = (RibbonItemSize)250;
            catch (System.Exception ex)
                Application.ShowAlertDialog(ex.Message);
        public void Initialize()
            CreateRibbonbtn();
            //throw new NotImplementedException();
        public void Terminate()
Message 8 of 11
Aravinth.Pichamani
Hi Yuan, I created my first button and WPF UI. Next, I need to develop the MVVM pattern. Above, I pasted the ribbon button code. Could you please help me? when I'm clicking that button window not showing.
Message 9 of 11
norman.yuan
If you read my reply carefully, you should have seen this
<QUOTE>
</QUOTE>
That is, in your code, simply add 1 line code:
            try
                btn.Text = "Lable";
                // Set CommandParameter to an existing command,
                // be it a built-in one, or your own command
                btn.CommandParameter = "ShowMyUI "
Of course, you need to update your RibbonCommandHandler code as I showed in my previous reply and you would have a CommandMethod that defines the corresponding command "ShowMyUI", also showed in my previous reply.
Also, I assume your code is just concept-proving code. That is, in real world, you would not run the CreateRibbonBtn() method directly in the IExtensionApplication.Intialize(). This has been discussed in this forum many times, years. You can search "Ribbon" in this forum for the past discussion, and especially pay attention to the answers provided by @ActivistInvestor
Norman Yuan
Drive CAD With Code
Message 10 of 11
Aravinth.Pichamani
Hi yuan i tried what you are showing the code still not working
Message 11 of 11
norman.yuan
There is nothing I can tell without see all the code. I only know you have a RibbonButton available. So, the first question is: did you debug the ribbonbutton click by placing a break point in the RibbonCommandHandler? If the break point is hit, you should clearly see what the issue is, such as whether the command assigned to the CommandParameter is executed by Document.SendStringToExecute().
Norman Yuan
Drive CAD With Code
