Streatch Command code in C#.net to streatch multiple segements of closed polygon
kbharathy9
1,059 次查看
8 条回复
1 条消息(共 9 条)
kbharathy9
I want to streatch multiple segments of closed polygon using C#.net as we can streatch with AutoCAD command.
0 个赞
已接受的解答 (1)
1,060 次查看
8 条回复
回复 (8)
2 条消息(共 9 条)
b_karunakar75
I will check and let you know
0 个赞
3 条消息(共 9 条)
kbharathy9
Please condiser Jig while streatching the feature.
0 个赞
4 条消息(共 9 条)
_gile
已接受的解答
Here's a PolylineStretchJig example (the 'indexes' parameter contains the polyline indexes to stretch).
class PolylineStretchJig : EntityJig
    Polyline _pline;
    Plane _plane;
    Dictionary<int, Point2d> _vertices;
    Point3d _basePoint, _dragPoint;
    public PolylineStretchJig(Polyline pline, Point3d basePoint, List<int> indexes) : base(pline)
        _pline = pline;
        _plane = new Plane(Point3d.Origin, pline.Normal);
        _vertices = indexes.ToDictionary(i => i, i => pline.GetPoint2dAt(i));
        _basePoint = basePoint;
    protected override SamplerStatus Sampler(JigPrompts prompts)
        var jppo = new JigPromptPointOptions()
            Message = "\nSpecify second point: ",
            BasePoint = _basePoint,
            UseBasePoint = true
        var result = prompts.AcquirePoint(jppo);
        if (result.Value.IsEqualTo(_dragPoint))
            return SamplerStatus.NoChange;
        _dragPoint = result.Value;
        return SamplerStatus.OK;
    protected override bool Update()
        Vector2d vector = (_dragPoint - _basePoint).Convert2d(_plane);
        foreach (var vertex in _vertices)
            _pline.SetPointAt(vertex.Key, vertex.Value + vector);
        return true;
A testing command (should work as expected when View == Top).
public void Test()
    var doc = Application.DocumentManager.MdiActiveDocument;
    var db = doc.Database;
    var ed = doc.Editor;
    var promptEntityOptions = new PromptEntityOptions("\nSelect Polyline to strech: ");
    promptEntityOptions.SetRejectMessage("\nSelected object is not a polyline.");
    promptEntityOptions.AddAllowedClass(typeof(Polyline), true);
    var promptEntityResult = ed.GetEntity(promptEntityOptions);
    if (promptEntityResult.Status != PromptStatus.OK)
        return;
    var promptPointResult = ed.GetPoint("\nSelect vertices to stretch: ");
    if (promptPointResult.Status != PromptStatus.OK)
        return;
    var promptCornerResult = ed.GetCorner("\nSpecify the opposite corner", promptPointResult.Value);
    if (promptCornerResult.Status != PromptStatus.OK)
        return;
    using (var tr = db.TransactionManager.StartTransaction())
        var ucs = ed.CurrentUserCoordinateSystem;
        var extents = new Extents3d();
        extents.AddPoint(promptPointResult.Value);
        extents.AddPoint(promptCornerResult.Value);
        extents.TransformBy(ucs);
        var pline = (Polyline)tr.GetObject(promptEntityResult.ObjectId, OpenMode.ForWrite);
        var indexes = new List<int>();
        bool IsPointInside(Point3d pt) =>
            extents.MinPoint.X <= pt.X &&
            extents.MinPoint.Y <= pt.Y &&
            extents.MinPoint.Z <= pt.Z &&
            pt.X <= extents.MaxPoint.X &&
            pt.Y <= extents.MaxPoint.Y &&
            pt.Z <= extents.MaxPoint.Z;
        for (int i = 0; i < pline.NumberOfVertices; i++)
            if (IsPointInside(pline.GetPoint3dAt(i)))
                indexes.Add(i);
        if (indexes.Count == 0)
            return;
        promptPointResult = ed.GetPoint("\nSpecify base point: ");
            return;
        var basePoint = promptPointResult.Value.TransformBy(ucs);
        var jig = new PolylineStretchJig(pline, basePoint, indexes);
        var promptResult = ed.Drag(jig);
        if (promptResult.Status != PromptStatus.OK)
            return;
        tr.Commit();
Gilles Chanteau
GileCAD
GitHub
5 条消息(共 9 条)
ActivistInvestor
Hi @_gile, aside from performance reasons with a large number of vertices, I can think of several other reasons why I would prefer using Entity.MoveStretchPointsAt() verses manually moving each vertex as per your example.
Those other reasons are related to hatching: associative dimensions; and more generally, involvement in any kind of associative network where other objects have a dependence on the polyline.
Also, with Entity.MoveStretchPointsAt(), the solution would stretch any Entity, rather than just polylines.
Here is your example, hastily refactored to work with any Entity (untested):
using System;
using System.Linq;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
/// <summary>
/// Gile's example, refactored to stretch
/// any type of Entity that can be stretched.
/// </summary>
namespace Examples
   class EntityStretchJig : EntityJig
      Entity entity;
      IntegerCollection indices;
      Point3d basePoint;
      Point3d lastPoint;
      Point3d samplePoint;
      public EntityStretchJig(Entity entity, Point3d basePoint, IntegerCollection indexes)
         : base(entity)
         if(entity == null)
            throw new ArgumentNullException(nameof(entity));
         if(!entity.IsWriteEnabled)
            throw new Autodesk.AutoCAD.Runtime.Exception(ErrorStatus.NotOpenForWrite);
         Point3dCollection stretchPoints = new Point3dCollection();
         entity.GetStretchPoints(stretchPoints);
         if(stretchPoints.Count == 0)
            throw new ArgumentException("Can't stretch the given entity");
         if(indices.Count > stretchPoints.Count)
            throw new ArgumentException("Invalid index array");
         if(indices.Cast<int>().Max() >= stretchPoints.Count)
            throw new IndexOutOfRangeException();
         this.entity = entity;
         this.indices = indexes;
         this.basePoint = basePoint;
         this.lastPoint = basePoint;
            BasePoint = basePoint,
            UseBasePoint = true
         if(result.Status != PromptStatus.OK)
            return SamplerStatus.Cancel;
         if(result.Value.IsEqualTo(lastPoint))
         samplePoint = result.Value;
         entity.MoveStretchPointsAt(indices, samplePoint - lastPoint);
         lastPoint = samplePoint;
         return true;
   public static class TestCase
      [CommandMethod("MYSTRETCH")]
      public static void Test()
         var peo = new PromptEntityOptions("\nSelect entity to strech: ");
         var per = ed.GetEntity(peo);
         if(per.Status != PromptStatus.OK)
            return;
         var ppr = ed.GetPoint("\nSelect vertices to stretch: ");
         if(ppr.Status != PromptStatus.OK)
            return;
         var pcr = ed.GetCorner("\nSpecify the opposite corner", ppr.Value);
         if(pcr.Status != PromptStatus.OK)
            return;
         extents.AddPoint(ppr.Value);
         extents.AddPoint(pcr.Value);
         using(var tr = db.TransactionManager.StartTransaction())
            var entity = (Entity)tr.GetObject(per.ObjectId, OpenMode.ForRead);
            tr.Commit();
         /// Let's try to avoid user interatiion inside an
         /// active transaction, to avoid undesired side-
         /// effects of aborting the transaction (e.g.,
         /// undoing transparent pans/zooms, etc.).
            ed.WriteMessage("\nCan't stretch selected entity.");
            return;
         IntegerCollection list = new IntegerCollection(stretchPoints.Count);
         for(int i = 0; i < stretchPoints.Count; i++)
            if(extents.Contains(stretchPoints[i]))
               list.Add(i);
         if(list.Count == 0)
            return;
         ppr = ed.GetPoint("\nSpecify base point: ");
            return;
         var basePoint = ppr.Value.TransformBy(ucs);
            var entity = (Entity)tr.GetObject(per.ObjectId, OpenMode.ForWrite);
            var jig = new EntityStretchJig(entity, basePoint, list);
            if(promptResult.Status != PromptStatus.OK)
               return;
            tr.Commit();
   public static class NoCopyAndPasteExtensions
      public static bool Contains(this Extents3d extents, Point3d pt)
         Point3d min = extents.MinPoint;
         Point3d max = extents.MaxPoint;
         return min.X <= pt.X && min.Y <= pt.Y && min.Z <= pt.Z
            && pt.X <= max.X && pt.Y <= max.Y && pt.Z <= max.Z;
6 条消息(共 9 条)
_gile
@ActivistInvestor
I didn't know this method.
Thanks for make me (us) discover it and for the code sample.
There's a little mistake (typo?) in the EntityStretchJig constructor: 'indices' instead of 'indexes' lines 36 and 38.
Gilles Chanteau
GileCAD
GitHub
0 个赞
7 条消息(共 9 条)
ActivistInvestor
Hi @_gile, thanks for pointing out that bug. The last thing I did before copying it was to move all the assignments to the bottom of the constructor, not realizing that was a mistake.
using System;
using System.Linq;
/// <summary>
/// </summary>
namespace Examples
      Entity entity;
      Point3d basePoint;
      Point3d lastPoint;
         : base(entity)
         if(entity == null)
         if(indexes == null)
            throw new ArgumentNullException(nameof(indexes));
         if(indexes.Count > stretchPoints.Count)
         if(indexes.Cast<int>().Max() >= stretchPoints.Count)
            UseBasePoint = true
         return true;
            return;
            return;
            return;
            tr.Commit();
         /// Try to avoid user interatiion inside an
            return;
               list.Add(i);
         if(list.Count == 0)
            return;
            return;
               return;
            tr.Commit();
8 条消息(共 9 条)
kbharathy9
Thank you @_gile . The code you shared is working fine for me.
0 个赞
9 条消息(共 9 条)
_gile
@kbharathy9
The code shared by @ActivistInvestor (message #7) is more robust. You should use it instead.
Gilles Chanteau
GileCAD
GitHub
0 个赞
