Strange visual glitches
john_stimacH3EQQ
john_stimacH3EQQ
I'm building a plugin with C# and I'm starting to occasionally see some strange visual glitches in my model space.
Looks like skewed and duplicated viewcube and UCS coordinate symbols. No amount of regen or refresh can make them go away. I need to start a new drawing for it to clear. Any ideas?
NVIDIA Quadro T2000
Windows 10, Pro
AutoCAD 2024
daniel_cadext
It’s probably not a high energy Muon blasting a bit of memory out of your memory card. The odds of that happening twice would be up there with Boltzmann brains. About the same as the odds of me guessing what your module does
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
kerry_w_brown
@john_stimacH3EQQ
As Daniel indicated, if it only happens when you run your code we'll need to see the code and know the circumstances.
Have you loaded the Performance Drivers for AutoCAD to suit your Graphics card.
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
