StatusBar Panes
StatusBar Panes
StatusBar Panes
Hey everyone,
I'm adding in a Pane to the Application statusbar and everything is good.
I then tried looking for some method/function call to display a context menu
when my pane is right clicked.
In ARX I would have called DisplayPopupPaneMenu off a pointer to the
statusbar. I might be being particularly blind today,
but try as I might, I cannot find anything similar in the managed
wrappers...except for a reference in the Managed Function to ARX Map in the
help. The funny thing is, this supposedly wraps MaximumWidth which takes an
Int...obviously cleverly disguised.
So has anybody got a context menu to work for a pane click event and would
care to share?
Cheers,
Glenn.
cgay
Glenn,
The documentation appears to be incorrect.
From the AutoCAD Managed Class Reference:
"MaximumWidth (Read/write)
Type
System.Int32
AcPane::DisplayPopupPaneMenu "
"virtual UINT
DisplayPopupPaneMenu(CMenu& menu);
menu Input menu object representing the context menu that will be displayed
This function displays a context menu above the pane. The context menu is aligned with the upper-left edge of the pane instead of being displayed where the user has clicked on the pane. This function should be used when displaying context menus for ACSB_POPUP style panes.
Returns an unsigned integer representing the ID of the menu item the user selected, or 0 if no menu item was selected
In .NET "Public Property MaximumWidth() As Integer", so i believe that this won't work.
But the 'Pane' class inherits from the 'StatusBarItem' class which exposes the event 'Public Event MouseDown(ByVal sender As Object, ByVal e As Autodesk.AutoCAD.Windows.StatusBarMouseDownEventArgs)'. I believe that you could use this event to catch the click then display your context menu.
Good Luck,
CG
Thanks for the reply.
Catching the click is not a problem...I am already doing that, however,
displaying the menu is eluding me.
I created a context menu in code, then when I try to use the show method of
the context menu, it wants a CONTROL object as one of arguments (the control
that owns the menu) and I can't see how to tie this back to the pane I
added.......
Any other suggestions?
wrote in message news:5005503@discussion.autodesk.com...
Glenn,
Type
System.Int32
"virtual UINT
won't work.
Good Luck,
CG
