SQL Server Express or higher?
wesbird
wesbird
  I'm evaluation Vault 2014 now, how do I dertermine which versin of SQL Server I should use, Express, Standard, or higher? where is the best practise? in the number of document, like 10,000 files? or size of documents, 10 Tb files?
Thank you so much
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
Hallex
I use succesfully SQl Server 2008R2 with A2014
without problem (either with C# and lisp)
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
dgorsman
Is this a programming issue, or should it go under the dedicated Vault board?
