Specifying Location Of Images For Ribbon (Relative Path)
I'm trying to specify the image source for ribbon images using relative syntax but having no luck.
If I use this:
button.LargeImage = new BitmapImage(new Uri(@"c:\\folderA\\folderB\\image.png") );
it works just fine. But it relies on absolute syntax, which is daft since it forces the code to be installed in a specific directory (or the images).
I've tried
button.LargeImage = new BitmapImage(new Uri(@"images\\image.png", UriKind.Relative) );
and
button.LargeImage = new BitmapImage(new Uri(@"images/image.png", UriKind.Relative) );
and I've tried placing the images subdirectory with the png file relative to the assembly, to the project source folder and even relative to AutoCAD itself - and in none of the cases do I get an image.
Can anyone shed any light on this for me? I'd like the images subfolder to be relative to the compiled assembly.
here a sample of my code for create my name of file containing the data of my prog :
Dim objAssemblyInfo As ApplicationServices.AssemblyInfo = My.Application.Info
My.Settings.GlobalFichierConfig = objAssemblyInfo.DirectoryPath & "\" & _
objAssemblyInfo.Title + ".cfg"
 with the objAssemblyInfo you retrieve info of your Dll.
