Specifying excel sheetname while creating datalinks
adamschilling8915
adamschilling8915
I have written some some to automate a task involving adding datalinks into autocad. I use workbooks that contain multiple tabs to create each individual datalink. THe issue that I am having is specifying which excel sheet tab to be used while adding that data link. I have automated finding the datalink name based on the sheetnames, but each time I run the program it only adds the first sheet in the workbook.
Thanks in advance.
Imports System
Imports System.IO
Imports System.Drawing
Imports System.Windows.Forms
Imports Microsoft.Office.Interop.Excel
Imports System.Windows.Forms.ListBox
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.Windows
Public Class fileselect
    Public Shared lb As Object
    Public Shared filename As Stream
    Public Shared fn As Object
    Public Shared xlsheet As Excel.Worksheet
    Public Shared xlwbook As Excel.Workbook
    Public Shared chkname As String
    Public Sub FileSelectButton_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles FileSelectButton.Click
        OFD.Title = "Select File Containing Databoxes"
        OFD.InitialDirectory = "G:/"
        OFD.Filter = "Excel File (*.xlsx)|*.xlsx| Excel File(*.xls)|*.xls|All Files (*.*)|*.*"
        OFD.ShowDialog()
    End Sub
    Private Sub OFD_FileOk(ByVal sender As System.Object, ByVal e As System.ComponentModel.CancelEventArgs) Handles OFD.FileOk
        Dim strm As System.IO.Stream
        strm = OFD.OpenFile()
        TextBox1.Text = OFD.SafeFileName.ToString()
        If Not (strm Is Nothing) Then
            'insert code to read the file data
            strm.Close()
        End If
        filename = OFD.OpenFile
    End Sub
    Private Sub TextBox1_TextChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles TextBox1.TextChanged
        OFD.FileName.ToString()
    End Sub
    Public Sub Button1_Click_1(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Dim xl As New Excel.Application
        fn = OFD.FileName
        xlwbook = xl.Workbooks.Open(fn)
        xlsheet = xlwbook.Sheets.Item(1)
        For Each sht In xlwbook.Worksheets
            CheckedListBox1.Items.Add(sht.Name)
        Next
        xlwbook = Nothing
    End Sub
    Private Sub MoveRight_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MoveRight.Click
        Dim selectedIndex As Integer = CheckedListBox1.SelectedIndex
        Dim checked As CheckedListBox.CheckedItemCollection = CheckedListBox1.CheckedItems
        If (selectedIndex <> -1) Then
            For i As Integer = 0 To CheckedListBox1.Items.Count - 1
                ' Get the selected item's check state.
                Dim chkstate As CheckState
                chkstate = CheckedListBox1.GetItemCheckState(i)
                ' Toggle the item state.
                If (chkstate = CheckState.Checked) Then
                Else
                End If
                ' Set the new state.
                CheckedListBox1.SetItemCheckState(i, chkstate)
            Next
        End If
    End Sub
    Private Sub MoveLeft_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MoveLeft.Click
                If (chkstate = CheckState.Unchecked) Then
                Else
                End If
            Next
        End If
    End Sub
    Private Sub Cancel_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Cancel.Click
        Me.Close()
    End Sub
    Public Sub nextbutton_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles nextbutton.Click
        ' Using checkedlistbox1 As New CheckedListBox
        If CheckedListBox1.Items.Count = 0 Then
            MessageBox.Show("Please select at least one")
        Else
            Dim selected As Integer = CheckedListBox1.SelectedIndex
            '******* THIS IS WHERE I NEED TO LOOK THE SHEET NAMES AND REFERENCES DATALINK OPTIONS STARTING AROUND LINE 165 *******
            'if (selected <> -1) Then
            '    For i As Integer = 0 To CheckedListBox1.Items.Count - 1
            '        'get itemes checked state
            '        Dim chkstatecreation As CheckState
            '        chkstatecreation = CheckedListBox1.GetItemCheckState(i)
            '        If (chkstatecreation = CheckState.Checked) Then
            For Each item In CheckedListBox1.CheckedItems
                chkname = item
            Next
        End If
        Call links.Datalinks()
    End Sub
End Class
Public Class links
    <CommandMethod("TFS")> _
    Public Shared Sub Datalinks()
        ' Hardcoding the string
        ' Could also select for it
        Dim selectedfile As String = fileselect.fn
        Dim dlName As String = fileselect.chkname
        Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Dim doclock As DocumentLock
        ed.WriteMessage(vbLf & "File selected was ""{0}"".", fileselect.fn)
        Dim ppr As PromptPointResult = ed.GetPoint(vbLf & "Enter table insertion point: ")
        If ppr.Status <> PromptStatus.OK Then
            Return
        End If
        'Remove the Data Link, if it exists already
        Dim dlm As DataLinkManager = db.DataLinkManager
        Dim dlId As ObjectId = dlm.GetDataLink(dlName)
        'If dlId <> ObjectId.Null Then
        '    dlm.RemoveDataLink(dlId)
        'End If
        ' Create and add the Data Link
        Dim dl As New DataLink()
        dl.DataAdapterId = "AcExcel"
        dl.Name = dlName
        dl.Description = "Excel fun with Through the Interface"
        dl.ConnectionString = fileselect.fn
        dl.DataLinkOption = DataLinkOption.None
        dl.DataLinkOption = DataLinkOption.PersistCache
        dl.DataLinkOption = CellOption.InheritCellFormat
        dl.UpdateOption = dl.UpdateOption Or CInt(UpdateOption.AllowSourceUpdate)
        doclock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument
        dlId = dlm.AddDataLink(dl)
        'MessageBox.Show("nothing")
        Dim tr As Transaction = doc.TransactionManager.StartTransaction()
        Using tr
            tr.AddNewlyCreatedDBObject(dl, True)
            Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
            Dim tb As New Table()
            tb.TableStyle = db.Tablestyle
            tb.Position = ppr.Value
            tb.SetDataLink(0, 0, dlId, True)
            tb.GenerateLayout()
            Dim btr As BlockTableRecord = DirectCast(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
            btr.AppendEntity(tb)
            tr.AddNewlyCreatedDBObject(tb, True)
            tr.Commit()
        End Using
        ' Force a regen to display the table
        ed.Regen()
    End Sub
End Class
Balaji_Ram
Hello Adam,
Sorry for the delay.
Have you tried setting the connectionstring as <Excel FileName>!<Sheet Name> ?
Balaji
Developer Technical Services
Autodesk Developer Network
adamschilling8915
I have figured it out.
dl.ConnectionString = fileselect.fn + "!" + dlName
 Thanks for the reply!
when i try to link the entire sheet it works just fine.
dl.ConnectionString = ofd.Filename & "!" & sheetNames(a)
but when i add a range behind the code it gives the bad connection exception.
dl.ConnectionString = ofd.Filename & "!" & sheetNames(a) & "!" & rangeNames(a)
  why would that be ? any suggestions ?
hgasty1001
I'm not sure, but may be the connection string does not support a range, usually a connection string specify the connection parameters to a data base, at the database level, not the table level. As the docs aren't very useful, I would create a drawing with a linked table using the "Datalink" command, and then inspect  with a .NET application the datalink object to extract the format that Autocad is using.
Gaston Nunez
