- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Afternoon Everyone,
I am writing a drawing number transposition plugin that will iterate all MText, DText, MLeaders etc in a drawing.
The below code flies through the Mtext, but struggles on the MLeader.
private static void process_QualifiedNumbers()
DateTime start = DateTime.Now;
processMText_Qualified();
DateTime end = DateTime.Now;
Ed.WriteMessage("\n{0} Mtext processed in {1}s", MText.Count, end.Subtract(start).TotalSeconds);
processMLeader_Qualified();
end = DateTime.Now;
Ed.WriteMessage("\n{0} MLeaders processed in {1}s", Multileaders.Count, end.Subtract(start).TotalSeconds);
private static void processMText_Qualified()
foreach (MText mt in MText)
foreach (DrawingNumber dwg in DrawingNumbers.List)
if (mt.Contents.Contains(dwg.ProjectNumber))
mt.Contents = mt.Contents.Replace(dwg.ProjectNumber, dwg.ClientNumber);
private static void processMLeader_Qualified()
foreach (MLeader ml in Multileaders)
if (ml.MText.Contents.Contains(dwg.ProjectNumber))
ml.MText.Contents = ml.MText.Contents.Replace(dwg.ProjectNumber, dwg.ClientNumber);
The output is
8 Mtext processed in 0.0468003s
22 MLeaders processed in 71.9402444s
however the MLeader text does not change.
Am I doing something wrong? Is there a way to speed it up and get the MLeader text to change?
Cheers,
Brent
