setting SymbolTableRecord.Name throws "eInvalidInput" exception
cgcamilo
cgcamilo
Hello, I am trying to integrate the new RealDWG 2018 library into my application. I used it to export dwg geometries.
I noticed that when creating BlockTableRecord objects (which inherits from SymbolTableRecord), setting "Name" attribute to a string that contains "/" character throws "eInvalidInput" exception. My question is, is it possible to know all "invalid" characters?
BlockTableRecord ret = new BlockTableRecord();
ret.Name = "example a/b" // eInvalidInput exception
Camilo Cifuentes
Keith.Brown
You can use SymbolUtilityServices.ValidateSymboleName(string name, bool allVerticalBar) to check if your proposed name is correct.
cgcamilo
Hello Keith,
Thank you for your answer. You led me to the correct place. I didn't know about those utility methods. However, I found this one more useful "SymbolUtilityServices.RepairSymbolName(some_name, false)".
Camilo Cifuentes
