Set UseBasePoint for DBText
Hi All,
I have a problem, hope everybody can help me. This is, where can i put this code: ppo.UseBasePoint = True ,ppo.BasePoint = pt1,ppo.UseDashedLine = True into my program:
 <CommandMethod("dd")> Public Sub DrawText()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = doc.Editor
        Dim db As Database = doc.Database
        doc.LockDocument()
        Dim ppo As PromptPointOptions = New PromptPointOptions("")
        ppo.Message = vbLf & "Choose the first vertex of the square:  "
        Dim ppr As PromptPointResult = ed.GetPoint(ppo)
        If ppr.Status <> PromptStatus.OK Then
            Return
        End If
        Dim pt1 As Point3d = ppr.Value
        '' Start a transaction
        Using acTrants As Transaction = db.TransactionManager.StartTransaction()
            Dim acBlkTbl As BlockTable
            acBlkTbl = acTrants.GetObject(db.BlockTableId, _
            OpenMode.ForRead)
            '' Open the Block table record Model space for write
            Dim acBlkTblRec As BlockTableRecord
            acBlkTblRec = acTrants.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _
                                            OpenMode.ForWrite)
            ''Create a single-line text object
            Dim acText As DBText = New DBText()
            acText.SetDatabaseDefaults()
            acText.Position = ppr.Value
            acText.Height = 100
            acText.TextString = "Cadviet"
            acText.WidthFactor = 0.8
            acText.HorizontalMode = TextHorizontalMode.TextCenter
            acText.VerticalMode = TextVerticalMode.TextVerticalMid
            acText.AlignmentPoint = ppr.Value
            acBlkTblRec.AppendEntity(acText)
            acTrants.AddNewlyCreatedDBObject(acText, True)
            acTrants.Commit()
        End Using
        ppo.Message = vbLf & "Choose the second vertex of the square:  "
        ppo.BasePoint = pt1
        ppr = ed.GetPoint(ppo)
    End Sub
 I use "MULTIPLE" in comman line of autocad, so i want to create one more acText.  Thanks Everybody.
Ajilal.Vijayan
Sorry, didnt understand you question correctly.
What is the purpose of picking those two points ?
You want to place text at those two points ?
This meaning. I want to create a lot of text "CadViet" and They have to aligned, i use UsebasePoint do that. Example: I want to draw 2 text "CadViet" into autocad. I will draw first text and next text have to align following the first text. Thanks very much.
Hallex
You can just clone text something like this:
        <CommandMethod("dctext")> _
        Public Sub DrawCopyText()
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            doc.LockDocument()
                Return
            End If
                OpenMode.ForRead)
                                                OpenMode.ForWrite)
                acText.Position = pt1
                acText.Height = 100
                acText.AlignmentPoint = pt1
                ppo.BasePoint = pt1
                Dim pt2 As Point3d = ppr.Value
                Dim vec As Vector3d = pt2 - pt1
                Dim acText2 As DBText = CType(acText.Clone, DBText)
                acText2.TransformBy(Matrix3d.Displacement(vec))
                acBlkTblRec.AppendEntity(acText2)
                acTrants.AddNewlyCreatedDBObject(acText2, True)
                acTrants.Commit()
            End Using
        End Sub
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Thanks so much
