set current text style
how can I change the current text style?
chiefbraincloud
If I may rephrase...
How can you Modify properties of the Style set as the current style?
you would use it's objectID to open it as a TextStyleTableRecord and modify it.
How can you Set the Current text Style to a different (existing) text style?
The Database.Textstyle property is not listed as read only, so you should be able to assign it the ObjectID of the Textstyle you want.
to get the ObjectID, use the Item property of the TextStyleTable.
Most system variables which are stored with the drawing
have counterpart properties on the Database class that
allow you to set/get their values.
See the TextStyle property of the Database. The value
of that property is not the name of the text style, it is the
ObjectId of the text style's TextStyleTableRecord.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
"Ray S Whitmore" wrote in message
news:6320382@discussion.autodesk.com...
