Set Angled UCS
Set Angled UCS
abdulhaseeb114
Set Angled UCS
abdulhaseeb114
I am getting 3 points from user and then I need to set the UCS in angled as shown in the picture
Please Help Me.....
kerry_w_brown
Have you tried something like this :
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-NET/files/GUI...
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
_gile
Maybe this is more readable:
private Matrix3d Ucs3Points(Point3d origin, Point3d pointX, Point3d pointY)
    Vector3d toXAxis = origin.GetVectorTo(pointX).GetNormal();
    Vector3d toZAxis = toXAxis.CrossProduct(origin.GetVectorTo(pointY)).GetNormal();
    Vector3d toYAxis = toZAxis.CrossProduct(toXAxis).GetNormal();
    return Matrix3d.AlignCoordinateSystem(
        Point3d.Origin, Vector3d.XAxis, Vector3d.YAxis, Vector3d.ZAxis,
        origin, toXAxis, toYAxis, toZAxis);
Use with current UCS defined points (e.g. got with ed.GetPoint()):
ed.CurrentUserCoordinateSystem *= Ucs3Points(org, ptX, ptY);
Use with WCS defined points:
ed.CurrentUserCoordinateSystem = Ucs3Points(org, ptX, ptY);
Gilles Chanteau
GileCAD
GitHub
